L3710 and Woods9000 Backhoe - Adding a Thumb
/ L3710 and Woods9000 Backhoe - Adding a Thumb #1
Woodsman603
North Country
Kubota L3710
Looking to add a thumb to my L3710. Prefer hydraulic, but a manual one is fine. I've got a Hobart 180 220v welder on mixed gas, so I'm fine with welding.
The Woods9000 backhoe runs off its own hydraulics from the rear PTO. Where would I be tying into to get the thumb going? I'm going to have to get another lever, correct? I understand about 10% of hydraulics. I did setup the 3rd function on the front to angle the snow plow from EA and that's about it. There a kit or anything that I could get to tie into the hydraulics? I'm thinking I'm going to have to go with a manual kit.
Thanks.
/ L3710 and Woods9000 Backhoe - Adding a Thumb #2
Kubota uses a foot lever to activate the valve for the thumb ,Yes you need a valve and tie it in with the rest of them..........
mmk. that's a start. I'll look up foot levers for Kubotas. thanks.
I can post pictures later.......
That'd be great.
I see Kubota backhoes, but nothing for Woods9000. Not exactly sure what search parameters I need to be looking up.
/ L3710 and Woods9000 Backhoe - Adding a Thumb #6
Does woods offer a hyd thumb?
I'm poking around and found this:
Woods BH9 Backhoe Backhoe Attachment: Thumb 19778 Assembly Assembly Parts and Diagram
But that's for a mechanical one.
I may just end up going with a Titan Attachments weld on setup. Think that's going to be the most straightforward way.
/ L3710 and Woods9000 Backhoe - Adding a Thumb #8
Thanks for the pics. That off your L3800?
It almost looks like I'll have to go with a manual though. Unless there's a kit of some sort which I'm not finding.
/ L3710 and Woods9000 Backhoe - Adding a Thumb #12
I guessing they offer a valve kit for it ...
/ L3710 and Woods9000 Backhoe - Adding a Thumb #14
Woods shows it as a option for a hyd thumb, So call the dealer and ask them how much money .....
mmk. shipped them an email. See what it would take/cost.
The Titan manual setup is going to be ~$300 which is fine. If I'm going to be creeping over $1000 on this, I'll probably just stick with the manual. We'll see.
/ L3710 and Woods9000 Backhoe - Adding a Thumb #16
Over 1k easy.......
/ L3710 and Woods9000 Backhoe - Adding a Thumb #17
You can do it yourself not to hard........
I'm fine with the welding. But I cannot explain how terrible I am at hydraulics. I get so lost. I've had my attempts a few times and its only miserably. The worst was setting up full hydro in a custom 4x4 buggy. I lost my shirt trying to figure all that crap out. The Third Function from EA was great though. Just plug an play.
I'm going to see what those two places have to say. I have a rising suspicion I'll be going with a manual though. Which, I guess, is better than nothing.
/ L3710 and Woods9000 Backhoe - Adding a Thumb #19
I don't think you have to weld the brackets should be on the hoe already....
/ L3710 and Woods9000 Backhoe - Adding a Thumb #20
If its older it might not have the brackets.....
Case-IH 596 (A62180)
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
207274 (A52708)
207274 (A52708)
2019 John Deere TX Gator (A62183)
2019 John Deere TX...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
Kubota BX2370 (A62180)
