L3710 and Woods9000 Backhoe - Adding a Thumb
/ L3710 and Woods9000 Backhoe - Adding a Thumb #1
Woodsman603
North Country
Kubota L3710
Looking to add a thumb to my L3710. Prefer hydraulic, but a manual one is fine. I've got a Hobart 180 220v welder on mixed gas, so I'm fine with welding.
The Woods9000 backhoe runs off its own hydraulics from the rear PTO. Where would I be tying into to get the thumb going? I'm going to have to get another lever, correct? I understand about 10% of hydraulics. I did setup the 3rd function on the front to angle the snow plow from EA and that's about it. There a kit or anything that I could get to tie into the hydraulics? I'm thinking I'm going to have to go with a manual kit.
Thanks.
/ L3710 and Woods9000 Backhoe - Adding a Thumb #2
Kubota uses a foot lever to activate the valve for the thumb ,Yes you need a valve and tie it in with the rest of them..........
mmk. that's a start. I'll look up foot levers for Kubotas. thanks.
I can post pictures later.......
That'd be great.
I see Kubota backhoes, but nothing for Woods9000. Not exactly sure what search parameters I need to be looking up.
/ L3710 and Woods9000 Backhoe - Adding a Thumb #6
Does woods offer a hyd thumb?
I'm poking around and found this:
Woods BH9 Backhoe Backhoe Attachment: Thumb 19778 Assembly Assembly Parts and Diagram
But that's for a mechanical one.
I may just end up going with a Titan Attachments weld on setup. Think that's going to be the most straightforward way.
/ L3710 and Woods9000 Backhoe - Adding a Thumb #8
Thanks for the pics. That off your L3800?
It almost looks like I'll have to go with a manual though. Unless there's a kit of some sort which I'm not finding.
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A59228)
2006 GEA Westfalia...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Equipment Trailer (A59230)
1986 Eager Beaver...
2014 Ford Transit Connect Passenger Van (A59230)
2014 Ford Transit...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2015 Chevrolet Cruize Sedan (A59231)
2015 Chevrolet...
CASE TV450B SKID STEER (A62129)
CASE TV450B SKID...
