3010 coolant overflows
/ 3010 coolant overflows #1
Jimdog571
Member
Milton Fl
1994 Ford 3930 and John Deere 3010
My gas 3010 is peeing out coolant from the overflow tube when it gets warmed up. I had removed the block heater and plugged it. It was teed into the bypass line and went to the drain plug in the block. I just installed a new clutch and it did not do this before. Assuming it was the thermostat I replaced it along with the cap and both hoses. Any suggestions? Removing the heater wouldn't have done it would it?
/ 3010 coolant overflows #2
Untill the radiator has a couple of inches of air space in the upper tank it will do so.
When the radiator is 100% full and not having a coolant recovery jug it will vent water till it establishes it's desired expansion space.
Here is where the heater was plumbed into.
I was hoping that is it but i had drained all coolant from the block too. I just checked it after letting it cool down and it is still full. Shouldn't the thermostat have opened up letting coolant fill the block back up then I would have needed to top it off.
/ 3010 coolant overflows #5
I can't say for sure on a 3010 but the bypass should have filled most of the block as you filled the radiator. If the block didn't have water up to the thermostat the thermostat will not work, also your temperature gauge will not work without being in water.
Taking the coolant level down 2 inches did the trick. I found my manual and it says it in there also. I guess I'm used to filling it to the top like in a car. Thanks for the help.
/ 3010 coolant overflows #7
Welcome, one thing we have done at times is replace the radiator cap with a newer style and add a coolant recovery bottle.
Cooling systems seem to hold up better without that air gap in the radiator.
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2019 Ford Explorer AWD SUV (A64557)
2019 Ford Explorer...
John Deere 6200 Tractor (A64047)
John Deere 6200...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2025 24in Mini Excavator Bucket Attachment (A64553)
2025 24in Mini...
MISC PALLET OF TRUCK PARTS (A65643)
MISC PALLET OF...
