Disc Harrow Massey #25 Disc
/ Massey #25 Disc #1
missesalot
Brockport NY
tc45d
I found what I believe to be a Massey #25 disc. It has the round pipe frame and the twin levers for adjusting the angles. It’s 8’ approximately. It’s in need of paint, but otherwise good condition. Might need one bearing box fixed or replaced, which I think is easy done. Couple questions:
Would this be a good match to my NH TC45d hydrostatic?
The man is asking $1000 and is not flexible on price. From a cursory look online, this doesn’t seem out of line.
Would love to have any advice you gents and ladies have. Thank you and happy Easter.
/ Massey #25 Disc #2
If a towed Disc Harrow is the appropriate implement for your application, go for it.
If your tractor is 4-WD I speculate your 3,300 pound bare tractor weight TC25d may grunt a bit, but should handle it OK. My Disc Harrows have been TPH mounted.
Others with Massey #25 and/or other towed Disc Harrow experience may contradict me.
What tractor does the harrow owner have?
As one who paid $1,300 for a very, very nice all-original Ford 101 series plow with Landing Lever several years ago, I can understand the attraction.
Here is a Monroe Tufline web page which may aid your decision:
TW5 Series Tandem Wheel Disc Harrows | Tufline
massey ferguson model 25 disc harrow - Google Search
/ Massey #25 Disc #3
I have a model 22, and love it. I believe the only differenceis, the 22 has wooden axle bearings, and the 25 cast iron type. Gangsare easily adjusted for angle of cut with the levers. Nice for going full cut for the first pass over, then straighten to preferred angle for the finish pass. Sure beats removing bolts to change the angle of cut.
Seems a bit high to me, especially needing a new bearing. We always figured 20% mark up at dealers for profit, and I'm guessing you checked dealer prices.
I'd hate to offer him $800 in greenbacks, and not really want it. Cash is still king. Although, the factor of the easy adjustment is worth something.
/ Massey #25 Disc #4
What about tractor vs disc draft force?
New Holland TC45
2001 - 2003 Boomer TC Series
Compact Utility tractor
Next model: New Holland TC45A
Manufacturer: New HollandVariants:
TC45: base model
TC45D: deluxe
New Holland TC45 Engine:
Shibaura 2.2L 4-cyl diesel
New Holland TC45 Power:
Engine (gross): 45 hp [33.6 kW]
Gear PTO (claimed): 39.6 hp [29.5 kW]
Hydro PTO (claimed): 37.8 hp [28.2 kW]
Capacity:
Fuel: 13 gal [49.2 L]
3-Point Hitch:
Rear Type: 1
Rear lift (at 24"/610mm): 2330 lbs [1056 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Dimensions
TC45 2WD Weight (shipping): 3,200 lbs [1451 kg]
TC45 4WD Weight (shipping): 3,349 lbs [1519 kg]
TC45D 4WD Weight (shipping): 3,417 lbs [1549 kg]
TC45D SuperSteer Weight (shipping): 3,586 lbs [1626 kg]
Wheelbase: 73.5 inches [186 cm]
SuperSteer Wheelbase: 81 inches [205 cm]
Length: 125.2 inches [318 cm]
SuperSteer Length: 129.6 inches [329 cm]
Width: 61.3 inches [155 cm]
Height (ROPS): 95 inches [241 cm]
Ground clearance: 14 inches [35 cm]
Front tread: 46.4 inches [117 cm]
Rear tread: 47.5 inches [120 cm]
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: hydrostatic power
Cab: Two-post ROPS.
Hydraulics:
Pump flow: 9.8 gpm [37.1 lpm]
Total flow: 14.9 gpm [56.4 lpm]
Steering flow: 5.1 gpm [19.3 lpm]
Electrical:
Ground: negative
Battery:
Number: 1
Volts: 12
Page information:
Last update: October 31, 2019
Copyright: Copyright 2019 TractorData LLC
Contact: Peter@TractorData.com
/ Massey #25 Disc
It is a 3 point disc, my tractor is 45hp.
/ Massey #25 Disc
New Holland TC45
Next model:New Holland TC45A
Manufacturer:New HollandVariants:
TC45:base model
TC45D:deluxe
Engine (gross):45 hp [33.6 kW]
Gear PTO (claimed):39.6 hp [29.5 kW]
Hydro PTO (claimed):37.8 hp [28.2 kW]
Capacity:
Fuel:13 gal [49.2 L]
3-Point Hitch:
Rear Type:1
Rear lift (at 24"/610mm):2330 lbs [1056 kg]
Rear PTO:independent
Rear RPM:540
Dimensions & Tires:
Wheelbase:73.5 inches [186 cm]
SuperSteer Wheelbase:81 inches [205 cm]
Weight:3200 to 3586 pounds
Front tire:5.50x16
Rear tire:13.6x24
Mechanical:
Chassis:4x2 2WD
4x4 MFWD 4WD
Steering:hydrostatic power
Cab:Two-post ROPS.
Hydraulics:
Pump flow:9.8 gpm [37.1 lpm]
Total flow:14.9 gpm [56.4 lpm]
Steering flow:5.1 gpm [19.3 lpm]
Electrical:
Ground:negative
Battery:
Number:1
Volts:12
Page information:
Last update:October 31, 2019
Copyright:Copyright 2019 TractorData LLC
Contact:Peter@TractorData.com
I’m not sure what you mean, I don’t know a lot about these.
/ Massey #25 Disc #7
If your MF TC45d has 4-WD it should pull an 8' width disc with 18" diameter pans fine.
The eight foot width with 20" diameter pans may be too much. Your TC25d may run out of traction/power with gang angles set aggessively or on second pass when soil is soft. Border line case.
The eight foot width with 22" diameter pans -- too much.
Bear in mind that I do not know your exact conditions.
In terms of your tractor, tractor weight is the primary factor in capability. Then 4-WD vs 2-WD and tractor horsepower in this case.
In terms of the disc, the draft force (implement resistance) is proportional to pan diameter, disc width, pan spacing (7" or 9") and gang angle adjustment.
Then there is your soil and soil moisture.......
/ Massey #25 Disc #8
I pull my 6' model 22 with a ford 2000 3 cyl gasser, w/28 hp on the drawbar, which had a straight 4 speed, but I installed a 3 spd.aux. transmission. It will pull it in 2nd gear, in direct drive just fine. I do know it's back there after a few passes, and the dirt is finer, set at full cut, going nearly into the hubs. Opens the governor some, but doesn't lug it by any means. The tires are loaded for weight, so traction isn't a problem. If you have weights, or 4-wd, it shouldn't be a problem, until you turn with 4-wd. Never had a tractor with 4-wd, but assume it's like all other 4-wd's, it turns much better with it disengaged.
/ Massey #25 Disc
Yes my machine is 4wd, and the tires are loaded
/ Massey #25 Disc #10
I pull my 6' model 22 with a ford 2000 3 cyl gasser, w/28 hp on the drawbar.
Your tractor weight and width is the same as my Kubota L3560.
Tire width is probably 64". So two disc widths would usually be 72" and 84". 84" disc is 17% wider/heavier than 72" disc and will require about 17% greater tractor traction and power to pull with all pan diameters and all and pan spacing.
/ Massey #25 Disc
In terms of your tractor, tractor weight is the primary factor in capability. The 4-WD vs 2-WD, then tractor horsepower.
My machine is a tc45d, not a tc25d. Only pointing that out as it seems relevant as a big difference in horsepower, to the extent that that matters. My soil is somewhat light. My intent is to scratch up the surface enough to broadcast clover on a 1 acre foot plot.
/ Massey #25 Disc #12
I pull my 6' model 22.
What diameter are the pans and what is your pan spacing?
18" is about 37 pounds bearing on each pan. 20" pans 52 pound bearing on each pan.
7" pan spacing has more float than deeper penetration 9" pan spacing.
Big differences in draft force resistance.
/ Massey #25 Disc
18" is about 37 pounds bearing on each disc. 20" pans 52 pound bearing on each disc.
Big differences in draft force.
I’m kicking myself for not taking a pic of it when I was there, I believe it’s 9” spacing and 18” pans at the most. Thanks a lot for your help. As far as weight goes, does leaving the loader and grapple on the front increase weight in a useful way relative to pulling a disc through soil?
/ Massey #25 Disc #14
This information would have been more helpful in Post #1.
/ Massey #25 Disc #15
I知 kicking myself for not taking a pic of it when I was there, I believe it痴 9 spacing and 18 pans at the most. Thanks a lot for your help. As far as weight goes, does leaving the loader and grapple on the front increase weight in a useful way relative to pulling a disc through soil?
FEL certainly increases tractor total weight, but FEL acts as counterbalance to your loaded rear tires, so combination when pulling a disc harrow may be neutral or somewhat helpful.
I remove my bucket for forward visibility when harrowing for an hour or two. I remove the entire FEL for forward visibility if I anticipate harrowing six hours or more.
/ Massey #25 Disc #18
If it’s that big of a problem to you , then you should move on to another thread.
And what? Would you have jumped in with a very helpful to the OP seventeen (17) words?
/ Massey #25 Disc #19
I have hundreds of hours using a 25 behind a Massey 135 gas tractor, you’ll have no problems pulling it. Not seeing the condition it’s hard to say on the price, but if your happy with it and works for you , it will be a good set up.
/ Massey #25 Disc #20
Least all my info comes from tens of thousands of hours of actual use and not from books and literature quoted over and over.
2014 International WorkStar 7400 T/A VacCon Combination Sewer Jetter Vacuum Truck (A61573)
2014 International...
2014 Dodge Charger Sedan (A61574)
2014 Dodge Charger...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59911)
2016 INTERNATIONAL...
2001 TAKEUCHI TL150 SKID STEER (A64279)
2001 TAKEUCHI...
2018 Chevrolet Equinox SUV (A61574)
2018 Chevrolet...
