Trac Vac: Cut down on dust cloud during use
/ Trac Vac: Cut down on dust cloud during use #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I love my Trac Vac 580 but I look like the Tasmanian Devil when I use it - a giant dust cloud fills the air. I was wondering if anyone had covered the wire mesh with anything that still allowed for adequate venting but would help my situation?
/ Trac Vac: Cut down on dust cloud during use #2
Did you ever find a solution? I’ve been looking for any ideas to keep the dust down. I have the 880
/ Trac Vac: Cut down on dust cloud during use #3
Hey snpower,
I did find a solution for the dust. I used a insulation removal bag 4’x6’. I modified it a little so it wouldn’t reach 6’ as the trailer isn’t that long. Worked well dust wise, but it did cut the power of the engine down a little. Nothing crazy. Was thinking about cutting a hole or slits on the bottom side of the bag to see if I could get the engine power back without releasing too much dust. Also installed some foam by attaching some foam pads to the screens.
Bags
(1) Insulation Removal Vacuum Bag - Super Heavy Duty Tear-Proof 6 FT X 4 FT - Easy-Fill SPOUT & Lowest DUST Filter - Contractors #1 Choice - EST 450 LBS / 75 CF PRO-450 (3.5 oz Strength) by RAM https://www.amazon.com/dp/B076VKV8P2/ref=cm_sw_r_cp_api_i_qgIIEb78B1NC0
Foam filter
Duraflow Filtration Mobile Home Foam Filter - 19 x 35 x 1/4 - Compatible with Coleman (Model # 7660-3401, 7660-340 and Nordyne (Model # 669073 & 669073R) - (1 Pack) https://www.amazon.com/dp/B07N8KWYR4/ref=cm_sw_r_cp_api_i_LfIIEb5A7E4PA
/ Trac Vac: Cut down on dust cloud during use #4
I have one as well and I was wondering if the removable gate to dump the leaves starts to bend on you guys. Mine does a bit. I retrofitted a piece of wood to keep it from doing that.
/ Trac Vac: Cut down on dust cloud during use #5
Mine did the first time I used the insulation removal bag. Once the bag filled up and there was enough force it popped the door off. Before that I was always careful when I took it off and how I placed it. But yes even with that I got a slight warp to it. How did the wood work out?
/ Trac Vac: Cut down on dust cloud during use #6
IT helped a bit. Im careful as well. I thought about making a new door made out of wood but i haven't yet. My original door still works fine. Side note. Mice chewed up the hose from the mower to the 3 pt blower. I replaced it. The replacement hose is see through. You can see the material gonng through the hose. I think its helpful
/ Trac Vac: Cut down on dust cloud during use #7
Just read this post.Guess maybe I'll try the bag thing.My 1080 Trac Vac is amazing but like you say Dust cloud everywhere.
/ Trac Vac: Cut down on dust cloud during use #8
I just got my new one yesterday. Just be careful to make sure that you shorten the length of the bag. When I used it in the fall the bag got so full it bent the door on the back of the trailer. I tried using some solid metal wire through the top of the trailers open top To secure foam type of filters. It worked a little note as well as the bag. Just realize it’s going to sound quieter and you’ll lose some power or suction.
/ Trac Vac: Cut down on dust cloud during use #9
I have had the Trac Vac 580 now for nearly 20 years.
Mods include:
- Replacing the top flimsy screens with "expanded metal mesh grid" from HD,
- Then the acorns and sticks poked holes in the vac drum I lined it with UHMW 1/16" x4" x48" inserted inside the drum then secured in with scews/lock nuts.
- Dumping/back door and reattach issue: The "dumping action" bent the back door bottom angle iron not allowing the door to be reinstalled easily So I straightened the bottom L steel angle then attached a 2x4 PT under the bottom frame to take the abuse of dumping heavy loads - no more fighting reattaching the back door!
- Discharge Chute to Trailer Connection: The metal clasp connection eventually breaks - I riveted a clasp on the pipe and hook on the trailer pipe that flips up for easy connection/reconnection.
/ Trac Vac: Cut down on dust cloud during use #10
Hey Carl_NH,
The expanded metal like this,
/ Trac Vac: Cut down on dust cloud during use #11
Yep that's it - doesn't clog or break like the original screen, and I used some 1/16" x 1" bar stock on the underside.
/ Trac Vac: Cut down on dust cloud during use #12
you can always water the ground before use, that'll work too!..
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
JOHN DEERE 7330 TRACTOR (A64276)
JOHN DEERE 7330...
Bush Hog 3008 (A64127)
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
