Trac Vac: Cut down on dust cloud during use
   / Trac Vac: Cut down on dust cloud during use #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I love my Trac Vac 580 but I look like the Tasmanian Devil when I use it - a giant dust cloud fills the air. I was wondering if anyone had covered the wire mesh with anything that still allowed for adequate venting but would help my situation?
   / Trac Vac: Cut down on dust cloud during use #2
Did you ever find a solution? I’ve been looking for any ideas to keep the dust down. I have the 880
   / Trac Vac: Cut down on dust cloud during use #3
Hey snpower,
I did find a solution for the dust. I used a insulation removal bag 4’x6’. I modified it a little so it wouldn’t reach 6’ as the trailer isn’t that long. Worked well dust wise, but it did cut the power of the engine down a little. Nothing crazy. Was thinking about cutting a hole or slits on the bottom side of the bag to see if I could get the engine power back without releasing too much dust. Also installed some foam by attaching some foam pads to the screens.
Bags
(1) Insulation Removal Vacuum Bag - Super Heavy Duty Tear-Proof 6 FT X 4 FT - Easy-Fill SPOUT & Lowest DUST Filter - Contractors #1 Choice - EST 450 LBS / 75 CF PRO-450 (3.5 oz Strength) by RAM https://www.amazon.com/dp/B076VKV8P2/ref=cm_sw_r_cp_api_i_qgIIEb78B1NC0
Foam filter
Duraflow Filtration Mobile Home Foam Filter - 19 x 35 x 1/4 - Compatible with Coleman (Model # 7660-3401, 7660-340 and Nordyne (Model # 669073 & 669073R) - (1 Pack) https://www.amazon.com/dp/B07N8KWYR4/ref=cm_sw_r_cp_api_i_LfIIEb5A7E4PA
   / Trac Vac: Cut down on dust cloud during use #4
I have one as well and I was wondering if the removable gate to dump the leaves starts to bend on you guys. Mine does a bit. I retrofitted a piece of wood to keep it from doing that.
   / Trac Vac: Cut down on dust cloud during use #5
Mine did the first time I used the insulation removal bag. Once the bag filled up and there was enough force it popped the door off. Before that I was always careful when I took it off and how I placed it. But yes even with that I got a slight warp to it. How did the wood work out?
   / Trac Vac: Cut down on dust cloud during use #6
IT helped a bit. Im careful as well. I thought about making a new door made out of wood but i haven't yet. My original door still works fine. Side note. Mice chewed up the hose from the mower to the 3 pt blower. I replaced it. The replacement hose is see through. You can see the material gonng through the hose. I think its helpful
   / Trac Vac: Cut down on dust cloud during use #7
Just read this post.Guess maybe I'll try the bag thing.My 1080 Trac Vac is amazing but like you say Dust cloud everywhere.
   / Trac Vac: Cut down on dust cloud during use #8
I just got my new one yesterday. Just be careful to make sure that you shorten the length of the bag. When I used it in the fall the bag got so full it bent the door on the back of the trailer. I tried using some solid metal wire through the top of the trailers open top To secure foam type of filters. It worked a little note as well as the bag. Just realize it’s going to sound quieter and you’ll lose some power or suction.
   / Trac Vac: Cut down on dust cloud during use #9
I have had the Trac Vac 580 now for nearly 20 years.
Mods include:
- Replacing the top flimsy screens with "expanded metal mesh grid" from HD,
- Then the acorns and sticks poked holes in the vac drum I lined it with UHMW 1/16" x4" x48" inserted inside the drum then secured in with scews/lock nuts.
- Dumping/back door and reattach issue: The "dumping action" bent the back door bottom angle iron not allowing the door to be reinstalled easily So I straightened the bottom L steel angle then attached a 2x4 PT under the bottom frame to take the abuse of dumping heavy loads - no more fighting reattaching the back door!
- Discharge Chute to Trailer Connection: The metal clasp connection eventually breaks - I riveted a clasp on the pipe and hook on the trailer pipe that flips up for easy connection/reconnection.
   / Trac Vac: Cut down on dust cloud during use #10
Hey Carl_NH,
The expanded metal like this,
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
2016 Ford F-350 Crew Cab Warner Service Truck (A48081)
2016 Ford F-350...
2022 Argo Xplorer XRT 570 LE 4x4 ATV (A48082)
2022 Argo Xplorer...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
