shooterdon
Elite Member
- Joined
- Nov 24, 2012
- Messages
- 3,568
- Tractor
- 2019 LS XR4140 HST Cab; 2020 Kawasaki Mule SX; 2021 Bad Boy 54" ZT Elite
I feel as though this is only going to end with herd immunity at this point. We will need ~ 70% infection rate I believe I read for it to die out. Containment doesn't seem to be working, or should I say, people aren't following directives.
So much wrong with that graph...or am I missing something.
With two identical infection rates, if one country has 300MM people it will have more cases than a country with 50MM people.
If you do no, or minimal testing, you get fewer cases.
Case 1 One country with 300MM tests 5% of the population with an infection rate of 50%...number of cases is 7.5MM
Case 2 Another country with 50MM tests 5% of the population with an infection rate of 50%...number of cases is 1.25MM
Case 3 Another country with 50MM tests 2% of the pollution with an infection rate of 75%...number of case is .75MM
Which country is doing a better job of containment?
Numbers need to be normalized to mean anything. IE. cases per 100,000 tested would have some use.
