Oil & Fuel Rust clogging fuel filter
/ Rust clogging fuel filter #1
1acre
Mahindra 2615
It looks like very fine rust particles are clogging my fuel filter. I have cleaned it once, but it clogged again in 1 hour of running. Will it damage anything if I continue to do this? Will the super fine rust that makes it past the filter hurt anything? Should I stop using my tractor until I get the tank rust free? This is a diesel Mahindra 2615 by the way.
/ Rust clogging fuel filter #2
Clean the tank and save yourself some trouble and money.....:)
/ Rust clogging fuel filter #3
You can clean the tank to remove the loose rust. That won't necessarily prevent it from happening again, just slow the progress. If you can remove the tank there are coatings you can apply to seal the metal. If you use them just be sure you don't seal any output fittings or petcocks. Fittings should be removed before application of the coat.
/ Rust clogging fuel filter #4
Stop using the tractor or install a pressure guage until the problem is solved. Rust can't get past filter but when filter clog's,injector pump starve's for lubercation. Some but not all injectors also suffer when starved. A dash mount pressure guage tell's you before flow drop's below critical point.
Now,I have questions. What happened when filter stoppd up? How did you clean the filter (more accurately,what did you do thinking you were cleaning the filter)?
/ Rust clogging fuel filter #5
You don't clean a fuel filter, you replace it!
Does your tractor have a metal tank? Most of the new ones are plastic. If it is metal it's rusting from water in the fuel. Condensation causes the water to get in so until you deal with that water will be a recurring problem. Do you have a water separator in the fuel delivery system or just the filter.? If you have just a filter is there a drain at the bottom of the filter canister? If so, get a clear container and drain a cup of fluid from it. Let it sit and see if there is a layer of water below the fuel. If there is than drain it daily until you find no more water.
/ Rust clogging fuel filter #6
As other said clean tank also fuel line plus check/clean fuel container.
/ Rust clogging fuel filter #7
In my experience it's not rust but microbe growth. Rust will stick to a magnet. Treat tank with biocide and or/other diesel fuel cleaning/water remover additive. Drain water out of tank if you can.
/ Rust clogging fuel filter #8
If it is a steel tank and actually rust I've used a telescoping pick up magnet, extend it out so the magnet is on bottom of tank and leave the handle resting in neck just under cap. Pull out and clean every time you fuel or more often to start, I've got one in a old pruning tower gas tank that's been there for years, B
I held a water hose to it in reverse :) Then sprayed with WD40 and carb cleaner, let dry.
I believe this was the issue. I cleaned and treated the tank and it seems fine now.
/ Rust clogging fuel filter #11
Had surging and poor performance last week. Checked sight glass on fuel bowl- critters in the bottom.
Removed & cleaned.
Runs like new again.
Check and see if there’s a tank drain on your tractor. If there is, park it when it’s low on fuel and let it sit a day or 2. Partially Open the drain over a 5 G bucket. See what comes out.
/ Rust clogging fuel filter #12
I'm betting he's talking about the water separator not the actual fuel filter.
28" PIPE DRAG (A64276)
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A61573)
2015 Ford F-450...
6' X 20' TRI-AXLE GOOSENECK TRAILER (A64280)
6' X 20' TRI-AXLE...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
(2) 460R85R38 TIRES W/ (8) LUG WHEELS (A64280)
(2) 460R85R38...
