New to me KX033-4
/ New to me KX033-4 #1
ZeroG
Meigs County SE Ohio
Kubota Grand L 3010, Kubota KX033-4
I've been shopping for an excavator for quite a while and finally found what appears to be the right one for me. A Kubota KX033-4.
It has 536 hours on it and is in pretty good shape. However it is missing the grease gun that came with it and was stored under the seat.
I'm wondering what that grease gun was like. Anyone have a pic of a kubota KX grease gun. I suppose I can order them from Kubota but I have not checked. I would like help with grease points to be sure I do not miss any.
Tips on safe operation would also be appreciated. I live in SE Ohio, very hilly terrain.
/ New to me KX033-4 #2
Its probably just a regular grease gun but ORANGE in color, Nice machine...:thumbsup:
/ New to me KX033-4 #3
My U35 purchased new has the bracket under the seat too. No grease gun from Kubota... just a spot for your own.
Or maybe dealers collect them.:laughing:
/ New to me KX033-4 #4
That's a nice machine. I bought my KX brand new, and while it has the spot for a grease gun, it didn't come with one from the factory.
/ New to me KX033-4 #5
I'm looking at how you chained that down on the trailer..did you wrap the chain around the track in the rear ?
/ New to me KX033-4
Thanks for the replies. I read the user manual and thought it implied one came with the machine. Oops. now I know for sure that is not the case. Thanks again.
Yes. Plus after the pic above was taken we moved one of the chains and added a heavy duty strap was added to the set up. No issues towing it home.
/ New to me KX033-4 #7
I have a KX121... never thought of wrapping a chain there. Have to see if it is possible on mine.
/ New to me KX033-4 #8
Nice machine. If you want a Kubota grease gun I bought one from my dealer because my name brand Lincoln was crap and always a headache and I happened to see one while getting some filters. The Kubota one was 30 bucks Canadian, made in China probably, but the most reliable hand gun I have ever used.
/ New to me KX033-4
I wasn't sure how to best tie it down. The ole feller I bought it from suggested that and I took his advice. Worked great.
/ New to me KX033-4
Thanks. I was frustrated with my cheap grease gun so I splurged and bought an Old Milwaukee ...Milwaukee 2646-20 M18 2-Spd Grease Gun Bare Tool. Since I have collected quite a few M18 tools and already have the batteries and charger it seemed like a good way to go. Reviews on amazon were impressive.
/ New to me KX033-4 #11
My friend has Milwaukee stuff. They are really good too. I ended up buying a Dewalt 20V grease gun because I had already bought my son some Dewalt stuff, so I had those batteries and chargers.
But I just saw one I really like. I can't remember if it was an Alemite or a Milwaukee but it actually had a digital display on it that shows how grease is in the tube. I thought that was awesome, because my guns never seem to run out until I crawl underneath something, LOL.
/ New to me KX033-4
That would be a good feature. This Milwaukee uses the plunger rod to show you about how much grease is left. I used it today but have not quite figured it out yet.
/ New to me KX033-4 #13
Congrats on your purchase! I just want to offer some advice, I wouldn't suggest tying it down by the rubber tracks if you're going to be moving it a lot, you don't want to tear or cut a track with the chain. There are plenty of places to chain it down from, I usually goto the blade and the welded "hoop" under the side without the blade. You can also usually tie down from somewhere on the track frame.
/ New to me KX033-4
Most of these I saw were mid 30's to high 30's. I feel lucky to have scarfed this one up for 28,5.
/ New to me KX033-4 #17
Awesome purchase. And it has a thumb!
7400 lbs is the size I want.
Change the track motor gear oil at same interval as the engine oil.
Oil is supposed to be changed at first 50 hours and every 500 thereafter.
But you don't know what they did.
It's simple, like 1/2 qt of 90wt and the track motors will last forever.
Every 200 hours is easy and low cost.
18v grease gun seems foo-foo but when you think about how much easier it is to maintain your machine, and how more likely you are to do it.
If nothing else, to justify the greasegun purchase price..... the electric greasegun will pay for itself.
I like the part where you can spin the carriage around while pumping grease onto the flank teeth.:cool2:
/ New to me KX033-4
I will only put 60 to 100 hours on it per year so I will change oil once a year like I do with my tractor.
I'll look at youtube for tips on changing track motors oil. I read about it but would like to see it done. Any suggestions on brand or synthetic or not for track oil?
I bought a Milwaukee 18v grease gun and you are right about making the job so much easier. Love it.
I'm totally lost on spinning carriage while greasing flank teeth. Where are the flank teeth? THX
/ New to me KX033-4 #19
656016d1589768537-new-me-kx033-4-a-flank-jpg
Cant see the (3) grease nipples under all that grease but you should have a similar greasing decal.
Owners manual says to grease the flank in 4 locations (Like North, East South West)
But you can spin the carriage while holding the trigger down on the 18v greasegun.
It's much more satisfying but my advice is to do it in private.
If anyone sees you having that much fun...... they will never understand and may judge harshly.
656017d1589768537-new-me-kx033-4-a-filldrain-jpg
Drain from the bottom and fill to the middle hole.
Super easy.
Just simple gear oil, 90 or 80/90.
Don't get hung up on oil type, just drain the oil with the metal dust out and refill with clean gear oil.
Special oil that you don't keep clean is not special anymore (if it ever was).
I put 300 hours on mine in 6 years that's like 50 hrs per year.
It sure seems like I use it more than that.
With a 7400 lb machine 300 hours of work would probably taken only 150 hrs.
/ New to me KX033-4
THANK YOU Sodo!!!!!!! I sure appreciate the info an pics. :D
