Buying Advice Box blade or rear blade?
/ Box blade or rear blade? #1
Bullwinkle123
Southern VT
Kubota MX5400HST, Z724XKW-3-54
I've been all over this forum trying to figure out which I need. Seems like people are about 45% in favor of box blade, 35% in favor of rear blade, and 20% in favor of some kind of rake (which, alone, I'm pretty sure will be useless for me, and I don't want to buy more than one 3ph implement for the time being).
I need to improve and care for the driveway in this photo album, if tractorbynet will let me post the link: Driveway Mar 09 2020 - Google Photos
It's more than 1/4 mile long, has some parts that have been professionally done, but always is degrading with time. Anyway, if you can take a look at the photos (and captions!) it'll give a clearer view of what I need to do.
I'm buying a new tractor _probably_ a Kubota MX5400, and have been pricing a 7' rear blade so far. I'm sure either can be used for the driveway. I'm not planning on any top-n-tilt hydraulics for now, mostly because I'm buying far more than I planned and need to draw the line somewhere. I'll have a loader/bucket, and am ready to order all the gravel I need.
Location is Vermont. Lots of mud, snow, mud, rocks, and mud, depending on the season. I'll be working to maintain a good crown and keep the drainage ditches clear. Otherwise I'm just one severe rain away from a washout.
Seeking your advice, and thanks in advance.
/ Box blade or rear blade? #2
A land plane would be best for pure driveway maintenance. Now if you want to use it for anything else you are back to one of the blades. I personally use a regular blade. A blade turned backwards does a good job of leveling and filling vs cutting.
/ Box blade or rear blade? #3
A land plane grading scraper (LPGS for short) is really, really good for maintaining a gravel road / drive. A good heavy one with scarifiers/ rippers is the easiest implement to use to maintain a road. Most of the time you don't need the scarifiers down, but sometimes you need to break it up to repair big potholes and they certainly come in handy. A good 6' one will run you $1,000 to $1,400 give or take.
/ Box blade or rear blade? #4
I would suggest something like this for rolling dirt, crowning and keeping ditches pulled..
Product Details
Product Details
I'll post a pic of my custom job..
/ Box blade or rear blade? #5
Ditching and snow removal I would lean towards blade.
Townline Equipment Plainfield,NH. having open house April 15th 10-4pm might offer a discount,also free eats. :licking:
/ Box blade or rear blade? #6
I would go with a good heavy scrape blade to start with then later a box blade
/ Box blade or rear blade? #7
(IMHO) Most driveways needs ditches to exist and not wash out (or become the water path "ditch"). I would hold this as priority #1. As such, a good heavy blade, that tilts is best for maintaining ditches in my opinion. Also good for snow removal as mentioned above.
Once you have a road that doesn't wash away, keeping it smooth and the potholes filled may be best done with a box blade or land plane. I don't have experience with these. I think crowning and "angling" a pitch can be done with these; just like smoothing can be done with a blade. But maybe not as easily as the other could do it. That is (IMHO), each has things they're better at, and not so good at, but still can do.
I've opted for a heavy 6-way (angle/tilt, rotate, offset)(or is that 3-way?) blade to do ditches and snow moving, then opted for a cheap TSC County Line rake to do the light pothole/ smoothing work.
/ Box blade or rear blade? #8
Those picture where the tire track is becoming the "ditch". Yikes! I agree, That can go bad quickly when a rainstorm triggers snow melt and a lot of rushing water. Some of those pictures look like you have some boulders, or shale rock lurking below.
Looks like you can bring material out of ditches as you crown, but a load or two of stone, from time to time, year to year, may help, or cover those lurking rocks. ...but they won't go away.
Snow banks can keep water getting into ditches. Not sure what the answer is other than "winging" (plowing) it back farther, or snow blowing.
Get ready for mud season! That'll test town roads in VT too!
p.s. It's good to take pictures and notes now of how the water sits, flows, or puddles, and what needs to be done. It'll be harder to see and remember when it's dry and there's no water to keep you honest when moving dirt.
/ Box blade or rear blade? #9
My driveway looks a whole lot like yours except it's a mile long. I also have one 120 foot section that is a " mud bog from H*ll". I have a very HD rear blade - heavy duty ROBB - big, heavy LPGS.
A whole lot of my driveway includes very large rocks. The LPGS is worthless in these sections. Actually - none of the three implements will do much GOOD in these heavy rock sections. Thirty nine years and the heavy rock sections are holding up just great.
On the muddy section - wait until it's just damp - trowel it smooth with my heavy rear blade - reversed.
I use the ROBB to scarify( it has scarifier shanks ) and repair - potholes & riffles, etc.
For my situation the LPGS has been a waste of money. They do best on a driveway with little large rock and a whole lot of finer crushed gravel, sand, etc.
If I had to choose one implement - my Rhino 950 @ 1050# and 96" wide. It clears snow - if we ever get enough to worry about. It will maintain the driveway ditches. Will move dirt for repair work - but not as well as the ROBB.
My driveway surface is a combination of large rock, gravel, sand, dust & volcanic ash. When it dries out, in the summer, it becomes concrete.
Summer repairs require the shanks on the ROBB - material relocation with the ROBB - final grading & smoothing with the rear blade.
The rear blade has the longest learning curve - then the ROBB - anybody can drag a LPGS and have good results. Good results with the LPGS are primarily determined by the surface material on the driveway. Heavy rock - forget the LPGS. Nice crushed stone, sand, etc - you can end up with a driveway that you can play a game of pool on. This is my tractor with the Rhino rear blade. I keep the rear blade on the tractor about 95% of the time as counter weight. View attachment 644688
/ Box blade or rear blade? #10
A rear (heavy) blade will do most of your work;also useful for snow removal.That being said a box blade will do a wonderful job on leveling DRY loose material. A box blade with scarifiers will move a lot of dirt.
/ Box blade or rear blade? #11
Get a back blade yhat has as many adjustments as possible. Yes, a back blade is surprisingly difficult to learn how to use well. It takes time.
Good ones do tend to cost more. Keep in mind that a good used back blade seems to me to work every bit as good as a new one. If you are in doubt about which one to get, go for the one with the heaviest construction even if used. After that, go for more adjustability.
All back blades will angle, and most will reverse the blade. It does that because that is how you pull it with the blade reversed in "smoothing mode". Reversing the blade is NOT for pushing dirt in reverse; that will bend most medium blades.
Other adjustments are offset from side to side, and angle tilt. Handy, but not essential. Even more sophisticated blade accessories are level adjusting shoes or a trailing wheel and removeable end caps.
But while you are learning the tricks of how to use a back blade as it was designed, you can use it with the blade reversed and lots of weight piled on top of the implement.
That is how you a blade is used in "smoothing mode", and it's easy to do and will do a lot for you. You will be surprised at how good a job a green horn can do at smoothing.
It's for when you basically have a good driveway, but it is in need of smoothing out the ruts and moving the top dressing around to be more even. Even ruts a foot deep.
From your photos, It looks like that is what your drive needs.
Using a back blade with the blade reversed will still give you the ability to improve the driveway a lot without making the usual learning mistakes. And there is lots of experimenting you can do even with the blade reversed.
For example you can experiment with float, "home made level adjusting shoes", and also home made end caps.
enjoy,
rScotty
/ Box blade or rear blade? #12
I have a bit shorter driveway in the mountains New Hampshire and I could not live without my back blade for snow removal. It will also do a fair job of maintaining the driveway in other seasons, so it is very versatile. Mine is a EA 6-way blade at 84" wide. I wouldn't consider a smaller blade even on my 25hp Kioti CK2610HST.
A box blade will do a better job maintaining driveways outside of snow season and be versatile enough to work fields, etc.
A land plane will do best for driveway maintenance, again without snow, but is a one trick pony.
/ Box blade or rear blade? #13
Get a heavy rear blade with tail wheel.
/ Box blade or rear blade? #14
Based on your tractor size, if you decide on a blade go with an 8 foot blade, not 7 foot To get a smooth driveway and avoid washboarding you will want to drag with an angle set on your blade. This means the width is reduced so a wider blade is preferred.
/ Box blade or rear blade? #15
Yep...
/ Box blade or rear blade? #16
Got a mile long gravel drive up and down hills and with plenty of curves. Beautiful drive through a forest. I have a blade and a box-blade. I rarely use the scraper blade for more than snow removal and, once a year, pulling some gravel back on the driveway. But the box blade does a great job. You can lengthen or shorten the top link (I'd get an hydraulic top line but my tractor has no remote for it) depending on the condition of your drive and what you want to do. Best way to see what different angles do is to simply try them. But I have another tool as well that does a really good touch-up job - my ratchet-rake on my FEL. It is great for grading out minor imperfections and bumps - also for pulling out boulders that may rise into the drive. I've used these tools now for almost 20 years and my drive looks pretty good. My BB has now worn so much on the sides that I'm getting some steel plates welded on to return it to like new.
/ Box blade or rear blade? #17
...but what if you're like the OP and can only have one?
Would you live without the scraper blade and use the BB for snow removal and to clean out the ditches and pull material back onto the driveway?
Or would you live without the BB and use the scraper blade?
/ Box blade or rear blade? #18
I dont understand limiting oneself to one tool. You need both!
The box blade (w/ teeth/rippers/scarifiers) is how you really disturb and churn material. If your drive needs heavy repair, you may have to attack it with this. Also will be your primary rear tool for landscaping DIRT, pulling it up, and dragging short distances, and smoothing.
The rear grader blade is best for pulling material on angles, into the center of the road, for restoring your crown, and smoothing the surface. Flip it around backwards for a more gentle attack. Also useful for cutting ditches (angle it hard into the ground), and of course, snow removal.
Get both. Look on craigslist, they are only $400-500 apiece.
/ Box blade or rear blade? #19
My problem with a choice is that the two implements have specific uses for me. The BB is primarily what I use for driveway maintenance. I also tilt it to dig or clean ditches. I can use it in reverse to level problem areas and neaten hillsides. The blade is used primarily for snow removal - for which a BB is totally useless. I have a limited budget - retired and all that - so my solution has been to purchase used implements. Everything I have except my JD tractor was purchased used. And I can tell you my BB and blade together cost a lot less than either new. Since these devices are very simple and open, it is easy to examine them and make sure you are getting a usable implement. It's hard to buy a dud if you simply keep your eyes open.
Thanks for recent replies. Since I'm buying a new tractor with a whole lot of stuff, I'm really trying to limit the "whole lot of stuff" part so that I survive this current financial craziness. (****, I probably need to add a shed for the attachments too, ouch). I already know I'd love to have both, but ONE for this year.
Based on what I'm reading it's probably the scraper. Most of the work this year is about repairing existing grades/crowns, and for the rougher portions I intend to bring in some truckloads of gravel to add a few inches and spread/grade/crown it with the scraper. (Hoping for tailgate spreads from the trucks bringing in the gravel, not sure if that will work in the forested portions). I hope that will be adequate, and of course the pro-BB entries eat away at my thoughts on this :)
As for ditch maintenance, that is problematic and people haven't weighed in too much on that. Those ditches are so variable in their size, the forest cruft that lands in them, and whether or not they have dirt under them or bedrock (which won't be good for any metal stuff scraping it, I think). I'd like to use the tractor to keep them clear, but it may be hopeless and require much shovel/rake time on my part
(or not, my back just won't do much of that).
Anyway, I appreciate all the feedback.
JOHN DEERE BWA 36 BLADE DISC HARROW (A63745)
JOHN DEERE BWA 36...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2006 Miller Built Gooseneck Trailer (A63116)
2006 Miller Built...
2011 John Deere 1770NT Planter (A63109)
2011 John Deere...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
