How do I get rid of a ton of roots?
/ How do I get rid of a ton of roots? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
Thread Rule One: I'm not buying anything else.! I have a BH, FEL, subsoiler/middlebuster, landscape rake, 48" tiller and a variety of hand tools (which hopefully won't come into play here).
I tore out a bunch of junk greenery, scrub brush, honeysuckle, small trees, etc. Used the BH and FEL to clear most of it. Then went at it with the rake and middlebuster. Turf is broken up and loosened. But it's loaded with roots. A big tangled mess. I plan on going over it again, maybe a few times with the middlebuster and rake to get as much as I can. I can't use the tiller yet as all this would just wind around the tines like rope which would take forever to get freed up.
Suggestions (other than buying something else)?
/ How do I get rid of a ton of roots? #2
When my BIL cleared farm land, he would bush hog roots that were sticking up,,
fresh dug roots are soft, and cut easily,,,
I thought about running the field/brush mower over the area, but it's far too rough right now due to ruts and dirt clods.
/ How do I get rid of a ton of roots? #4
The mower will help level the area and chop up roots!!! :D (reason I bought a used mower for cheap!!) ;)
/ How do I get rid of a ton of roots? #5
Keep it up with the middle buster. Make multiple passes north to south then east to west, then diagonally , 45 and 315 degrees. This should cut them up enough where the rake will work. I don't have a rake and i assume you dont have a box blade, but after i did all that with my middle buster, the box blade did a great job of finishing the destruction of the roots. Bear in mind i was doing this to eradicate bamboo and thicker roots will take longer to dig out.
^^ That's the only plan I have so far. More passes and cross passes, then rake. Repeat until .....
I've considered getting a rear blade for other tasks, but I can't see as I'll ever have use for a box blade. I'm hoping to find a used one though instead of paying $400+ for something that won't get much use.
/ How do I get rid of a ton of roots? #7
Dig under the root ball to remove the roots from the soil, using a mattock which has a beveled head and an ax head. Chop through the large roots with the ax head of the mattock. Use the beveled edge to dig out the soil as you work your way under the root ball.
/ How do I get rid of a ton of roots? #8
I had a similar problem, but only on 1/4 acre. I used my clamp-on pallet forks with my M4700. I'd angle them down slightly, set them on the ground, "plough" forward, lift and repeat.
/ How do I get rid of a ton of roots? #9
I used my box blade with the rippers all the way down and angled such that the blade itself does not engage. The rippers are close enough to get good coverage, but not so close that they get clogged up. Then I used a landscape rake to clean it all up. Worked quite well. The rest of the stuff you do not get will just rot away eventually. Used box blades are easy to find for under $300. Good luck!
Spent a couple of hours today between the MB and the rake. Got a lot more roots out, more than I expected. Still a lot to go, but it's ready for the tiller now:
(No, the big stumps in the back are not part of this. They were taken down last year to be used for firewood.)
/ How do I get rid of a ton of roots? #12
Looks great, from there I would stick the mower on top of it...grind away and level out...
Once you get it to a certain point ...digging up more roots is just more work..
/ How do I get rid of a ton of roots? #13
DANG!! That looks pretty nice to me! Good job!
After digging out what I could and breaking the rest up with the MB, I couldn't really walk through there. I had to basically crawl over it on the tractor to keep from being tossed out of the seat. Once I changed to the rake and started dragging the high spots off, it got a lot easier. The last few passes I could do at more like tilling speed.
/ How do I get rid of a ton of roots? #15
I think you have done a GREAT job with just the middle buster and rake. I know you don't want to spend $$$$ but I was going to suggest - look for a used four shanked ripper. My neighbor has a LARGE seven shank one that I borrowed. Removed the outboard shank on each side and it worked well on my M6040. Multiple shanks keep more of the roots contained. Every so often - stop, lift the implement - drop the roots.
Come back later and collect the piles with the grapple.
/ How do I get rid of a ton of roots? #16
I have a bunch of standing water at my house right now! I'm super jealous of this dry dirt.
/ How do I get rid of a ton of roots? #17
That sure is a beautiful spot you have there in ... "Lower Uncton"
1991 Duer 430HCD Towable Hydraulic Log Splitter (A59228)
1991 Duer 430HCD...
54in Bale Forks Tractor Loader Attachment (A59228)
54in Bale Forks...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
2022 Ram 2500 (A55973)
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
