Dump trailer hauling my tractor
/ Dump trailer hauling my tractor #1
Gulfmp
Member
Central ma
Kubota 2370-1, FEL, MMM, Box Scraper, 3Ph Snowblower
I am looking at buying CK2610 with field cab. I also would like to get a dump trailer. The trailer would be used independently mostly, but on very infrequent occasions I would need it to haul the tractor as well. What is the shortest low profile dump that will fit the tractor? I would love to only get a 10' dump because the storage area where it will live fits best with a 10'.
/ Dump trailer hauling my tractor #2
16' would be real tight. When I have mine in a 16' dump trailer with my loader and backhoe, backhoe jacked sideways into the corner and loader over the front of the dump box.... I had to turn sharp on switchback road and took out the tailgate, $600 OEM LED taillight and back corner of the bed. It was a $4800 repair.
If you do not have the backhoe, and you do not want to ever take a 3 point item with you, a 14' might make it with just tractor and loader with the loader inside.
10'???? I can't haul my side by side in a 10'. ****, my garden tractor would fit... But it wouldn't have tons of space.
/ Dump trailer hauling my tractor #3
While you can haul some tractors in a dump, it usually doesn't work out well. They are just way to small fo most machines & definitely to small if you have impliments.
Skidsteers & mini-exes are noticably more compact & what you see being easily hauled in a dump.
/ Dump trailer hauling my tractor #4
I haul a L3800 on a 16’ car hauler trailer. With the loader sitting on the front of the deck and a box blade attached it only clears the end of the deck by about 8”. If you didn’t have an implement on and backed it on and left the loader sticking off the back you might manage with a 10’ provided the weight distribution is safe. You really need a 12-14’ minimum without implements on the tractor.
/ Dump trailer hauling my tractor #5
Here’s the same tractor on my 24’ trailer. Implements fill a trailer fast. IMG_8395.JPG
/ Dump trailer hauling my tractor #6
On my 18’ equipment trailer my LS XR4040 with the loader and land plane is a tight fit.
I have a 10’ dump trailer. I love having a dump trailer and it fits is all kinds of small spaces but you can’t haul much in it. About 2 yards of gravel is maxed out. There isn’t much hope of hauling equipment in it. You might could fit a small (6000lb) excavator in it but I doubt the weight distribution would be right. Most 10’ dumps have dual 3500lb axles so that will be your biggest issue.
/ Dump trailer hauling my tractor #7
The tractor he’s looking at only weighs 2600 pounds base weigh. With a loader and loaded tires he’d still be within what two 3500 pound axels could carry. Length is the biggest factor. A dump trailer that could only carry 5,000 pounds or so wouldn’t be very useful though. That’s hardly any dirt or gravel.
/ Dump trailer hauling my tractor #8
They are heavy by design though, a 10k titled dump will easily weigh in around 3200-3500 lbs, leaving you 6500 in legal payload.
/ Dump trailer hauling my tractor #9
If the tractor tightly fits in the trailer, but the weight distribution is wrong, the tractor doesn't fit the trailer.
Bruce
I know I can't fit any implements in the trailer at the same time. I would make 2 trips for the once a year i would move the tractor off my site. I know it would be very tight, but if it fits-its ships! Balance is a different story
/ Dump trailer hauling my tractor #12
That leaves the tractor and implements separated causing the implements to be either loaded or unloaded by hand.
Bruce
/ Dump trailer hauling my tractor #13
2,500lbs L3200 on a 16' trailer... only way it worked at all was because of the really long tongue to set the bucket on. Made it more like a 18' trailer to some degree. It wouldnt work loaded backwards due to ballance issues.
As others have noted, you'll be loading or unloading impliments by hand on one end if you are planning multiple trips to get things done. Not something my back or patience is capable of.IMG_20140209_103755.jpgIMG_20140209_110007-1.jpg
/ Dump trailer hauling my tractor #14
As others have noted, you'll be loading or unloading impliments by hand on one end if you are planning multiple trips to get things done. Not something my back or patience is capable of.View attachment 644057View attachment 644058
My car hauler could be an 18’ I’m not 100 percent sure. Looking how tight yours is and mine fits in the deck it would almost half to be. I’ve never had any balance issues with mine. The short trailer would probably work better backing on especially with loaded tires. The OP could load the implements in the dump trailer and go dump them off and then go back for the tractor. I agree it would be annoying but for once a year maybe not that bad. I’m not sure if you could haul it at all on a 10” trailer though. Maybe if you left the bucket off and left the loader sticking off one end.
/ Dump trailer hauling my tractor #15
No idea what size your tractor is but that is a Massey SCUT in a 6x12
/ Dump trailer hauling my tractor #16
He's taking about a tractor sized slightly bigger than B2650. And you said you got your scut in there.... The loader and hoe are not in! He stands no chance at all.
/ Dump trailer hauling my tractor #17
If you do get a dump trailer long enough be sure and add D-rings to the trailer deck for tie downs. Guy I knew was a logger and moved his loader that way. One day going up hill his loader flew out the back, tail gates and all and went rolling down hill. Lucky no one was behind him. The loader wound up over into a ravine. Hard lesson on tie downs, or lack there of. He thought the brakes and tailgate were fail safe.
Ron
/ Dump trailer hauling my tractor #18
Yeah, that’s why I posted it, so he could see what 12’ looks like. The hoe is actually in, it’s just the angle of the picture.
/ Dump trailer hauling my tractor #19
My L47 TLB fit inside the 14' Lamar just fine.
2013 MITSUBISHI FE 4X2 S/A 20FT BOX TRUCK (A69167)
2013 MITSUBISHI FE...
2012 CAT D60-6 GENERATOR (A67714)
2012 CAT D60-6...
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft. Insulated Bucket Truck (A66736)
2012 Freightliner...
2021 Ford Explorer AWD SUV (A66738)
2021 Ford Explorer...
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
