Trash Can on a Pallet?
/ Trash Can on a Pallet? #1
Avenger
North Idaho
LS XR4145C
I live out in the country and stock pile my trash in cans in the garage. I would certainly do it outside, but lesson learned when a bear drug a full can though the forest.
I am tired of the smell and doing "dump runs" every 6-8 weeks. Not to mention the amount of space the cans take up.
One of my neighbors down the road has a metal trash bin, from our waste management, that gets dumped every two weeks. He keeps his down on the road and complains about people dumping their trash in his dumpster. Other neighbors use the curb pick-up style trash cans, but they have short driveways.
If I can swing it, I would like to get a metal dumpster and leave it by my garage, pick it up with the forks on my tractor to take it down to the road for pickup every two weeks. According to my neighbor who has a metal dumpster, the bears seem to leave it alone. However, I am concerned about the cost of doing this.
A cheaper way is doing the curb side weekly pickup using a smaller, plastic, bin on wheels. Dragging this down my driveway weekly would be a chore. I am uncertain about lifting it into the bed of my pickup as well due to weight and height of my bed.
My thought is, if I cannot get a metal dumpster, to somehow mount the plastic bin (without drilling holes in it) to a pallet and use the forks on the front of my tractor to move the bin up and down my driveway weekly. My issue is figuring out a way, without having a pallet OR the bin, to make this happen. I would hate to order this bin and find out that there is not real way of doing this.
Have you attempted this before? Can it be done? How can it be done? Please let me know.
/ Trash Can on a Pallet? #4
I have a 2 cu yd metal dumpster. Live in bear country and for some reason they do not touch it. I pay $12/mo rental and $24 to have it emptied. Minimum charge of one dump every 3 months. With just the two of us we never need to empty it more often.
No need to ever move it....the trash company drives up and dumps it. $240/yr is not cheap, but I do not deal with the smell or driving to the dump. Closest dump is 20 miles.
/ Trash Can on a Pallet? #5
Another option. Harbor freight trailer, build a ramp to roll you cans up and down. On the trailer empty at the house until full, roll off at bottom of driveway full.
See? This is why I love this community! I never thought of anything like those hitch-mounted things. THANK YOU.
I have a SSQA hitch receiver mount thing that would work like a charm.
(Mounting a can to a pallet... :thumbdown:)
But, keep the ideas rolling! I'm going to contact Waste Management early next week to see about pricing. I know its going to be more expensive having someone else come pick up my trash and take it to the dump for me, but the space it will give me, and the smell being gone, worth it.
/ Trash Can on a Pallet? #7
Talk to your refuse company for their solution.
/ Trash Can on a Pallet? #8
Set them on a pallet, pick up with your forks and bungee them to the SSQA. Not as sexy as the hitch receiver thingy but inexpensive. Looking at the hitch receiver contraption they were pulled by the vehicle not carried by the hitch like you would do with the front loader. I don't think you want to push them down the drive with your tractor.
/ Trash Can on a Pallet? #9
If the cans are that heavy, how are the guys supposed to dump them?
/ Trash Can on a Pallet? #11
A set of Edge Tamers with the added "Trash Tamers" would allow you to pick up the wheelie bin type trash cans with your FEL and bucket. Then you could carry them down to the road and set them down.
Link: R2 Manufacturing - Home Of The Edge Tamer
Where I'm at now, my trash guy pulls in (with my permission) and turns around in my driveway to pickup my wheeled bin and then drives out again. If I move to a location where the trash truck can't or won't make it down my driveway, I'll be adding these Trash Tamers to my Edge Tamers.
/ Trash Can on a Pallet? #12
Here, we use the plastic roll around cart with wheels the county furnishes and charges $15/mo for weekly pickup at the street. It's the same cart as shown in the video above.
The street is about 1/3 mile from the house, so I use the tractor forks to simply pick it up at the house and take to the street, then reverse when empty. I leave my forks positioned (all the time unless for some reason I need them out to max width) so they barely clear the cart sides near the wheel section, and as I raise them, the cart sides taper outward slightly and the forks have no problem holding the cart wedged between the forks. Even if the forks are slightly too wide apart, there is a lip on the cart top where the lid closes that doesn't let the cart slid thru the forks.
Just set it down at the street, lower the forks and back away. Nothing complicated about it.
/ Trash Can on a Pallet? #13
I have 2 30 gallon rubber/plastic type trash cans in the garage and make a dump run about every 2 weeks, and for the smell control (only needed in the summer) I have a large spray bottle filled with a pine sol/water solution (about 20%/80%) and spray a few skirts into the can every time I put some trash into the cans, this has worked well for the last 11 years.
At our gun club we have a large metal dumpster with metal doors on top that are chained and padlocked close with a small latched door in one of the top dumpster doors, and mostly summer campers stuff their food garbage in the dumpster.
2 years ago a bear tipped the dumpster on it's side and ripped open both doors and then had a picnic party until FWP trapped the bear, so unless the dumpster is "bear-resistant" from the testing at the "West Yellowstone's Grizzly and Wolf Discovery Center", good luck.
KC
/ Trash Can on a Pallet? #14
Anchoring the cans to a pallet permanently will probably not fly with the pickup trucks. The pallet would probably interfere with the handling and dumping mechanism on Waste Managements trucks. I used a lawn cart behind my mower to move to the road. Held two cans nicely. One garbage and one re-cycle each week.
Ron
/ Trash Can on a Pallet? #15
I added sides to some free pallets for firewood. Same concept as JoeyD...bungee them in.
/ Trash Can on a Pallet? #17
/ Trash Can on a Pallet? #18
Would a regular Carry-All type thing work for you to get the cans up and down the drive ? Can roll them on then lift to move.
gg
2012 WESTERNSTAR 4900FA (A63569)
2012 WESTERNSTAR...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
APPROX. 1000 GALLON FUEL TANK (A63291)
APPROX. 1000...
159119 (A60430)
159119 (A60430)
2004 WILDWOOD BUMPER PULL CAMPER TRAILER (A63569)
2004 WILDWOOD...
