What have you done to your Branson today?
   / What have you done to your Branson today? #461
I feel for you too, Lou. I am always amazed at how I hear of new ways that people use their tractor. Tell us about your PTO mounted generator, I've never seen one.
   / What have you done to your Branson today? #462
Here are a couple of pictures of it from back in 2016;
in the interior picture you can see the engine rpm required for the economy mode to output 540 pto rpm which provides 60 Hz power.
IMG_20160321_170856851.jpg IMG_20160321_170926996.jpg IMG_20160321_170935614.jpg IMG_20160321_171000162.jpg
The other day I ran it for about 5 hrs., shutdown for 6 hours then went back out and ran her for 3 more hours, shutdown for about 5 then ran for 1 hour and shut down again, by then the electrician had showed (but he has the flu) put his ladder up on the pole ran a new neutral wire down past the meter can and tied it in took care of the immediate problems, hopefully Monday he can mount the new meter base with the breaker disconnect and new cable up the pole to meet new code for the meter.
   / What have you done to your Branson today? #463
Nice rig Lou!
Does it bog at all in 540E under load? How many hours do you have on that beast now?
   / What have you done to your Branson today? #464
No noticeable bog with any load changes, I am not gentle with it when I put it on line.
I don't go thru the house breakers and turn everything off then bring them on one at a time,
I just flip the transfer on to generator with what ever wants power at that time, have never seen more then a 1 hz change for a second or so.
That is a 25KW generator but my normal load is usually less then 10 or 15KW.
I'm around 800 hours or so on her, maybe a bit more.
   / What have you done to your Branson today? #465
Cleared a little snow this evening. We had almost no snowfall, and very little remaining on the ground. But the last storm that started last night was very strong winds and piled what little snow we had into drifts right in front of the house and shop buildings. Took longer to warm up the tractor (plugged it in) than it did to clear the snow.
   / What have you done to your Branson today? #466
Pulled a few brush stumps up Yesterday. It could use a little more weight. Thinking wheel weights or ballast box for 3pt or both. Pulled from draw bar not the loader. Tried first with just tractor with no success. Hooked to the mower and it was able to remove the stumps but struggled a bit.
Anyone know a good source for wheel weights for the 15 series?
   / What have you done to your Branson today? #467
Mine got new glow plugs. 2 of the 3 were bad. It would start, but was hard and put out a bunch of white smoke at first. Now that’s gone. Bought the glow plugs on ebay and they are a perfect fit.
   / What have you done to your Branson today? #468
There are several places to order weights from, the couple that I looked at didn't list the 4815 but it all depends on the bolt holes in your wheels;
Branson Wheel Weights Suitcase Weights and Brackets
This one shows how to measure for the weights;
Wheel Weights | Taylor Foundry Company | Tractor Wheel Weights
What I put on my 8050;
Product Details - Lonestar Weights
Most places sell these weights in 1000# lots for the "free" shipping to a commercial location,
and you are looking at a bit over $1.00 per pound.
They are not inexpensive but I much prefer iron over liquid ballast, I'm running 1200# and ocassionally I'd like another 600#s.
   / What have you done to your Branson today? #469
Thanks for the information. I think I know why the don't list the 15 series, at least if my rim is like the others. No bolt holes for wheel weights. I would have to drill holes so for now, I am going to make sure the tires are as full as possible then look at building a ballast box.
   / What have you done to your Branson today? #470
Interesting. The older white wheels, had the holes pre-drilled for the counter weights. Looks like the new wheels don't have the holes.
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2019 F150 (A56435)
2019 F150 (A56435)
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56435)
2016 RAM 5500...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
