Kubota Quick connect coupler
/ Kubota Quick connect coupler #1
gregjo1948
Newark Valley,NY
Ford 2000 Industrial- Ford Jubilee-Ford 3400-IH 404-Farmal 504-Ih 284-Case 310
I recently bought a Kubota front loader LA344. It has a quick connect/disconnect coupler attaching the hydraulic lines to the tractor. I didn't get the part of the coupler that stays with the tractor when the loader is removed. I have the coupler part that has the locking handle that stays with the loader. Anyone know where I can get the coupler "receiver" that stays with the tractor. It has 4 quick attach couplers in line mounted on a plate. I don't need the control valve unit. thank you, gregjo1948
/ Kubota Quick connect coupler #2
As a rough guess I'll say the Kubota dealer should be able to provide it. Otherwise you could check with a hydraulic shop.
/ Kubota Quick connect coupler #3
Snap a photo. The couplers are identified as “male” or “female”. I assume when you say receiver you mean female?
/ Kubota Quick connect coupler #4
I believe he's talking about one of those "one hand, connect under pressure" setups that most manufacturers offer?? His tractor doesn't have it.
I don't know what Kubota tractor model that loader would come on?? If you know that you could then do a parts search on that tractor to see what's available? Or as Roadworthy said, talk to a Kubota dealer.
Were it me,,, I'd remove the fancy connector box and put four simple quick couplers on my tractor and convert the loader hoses to matching couplers?
/ Kubota Quick connect coupler #5
Plus one but if you do, don't forget to color code the lines and connectors. I use colored electrical tape for that.
That gang connector thing is a gimmick.
I think I will probably go with the quick couplers. I found the part I was looking for and it is $170.00 plus. thanks for the replies and help, gregjo1948
UNUSED CFG INDUSTRIAL H12R MINI EXCAVATOR (A62130)
UNUSED CFG...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
2017 Ford F-150 4x4 Pickup Truck (A61568)
2017 Ford F-150...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
2012 International 4300 Reefer Truck (A63118)
2012 International...
