Good morning!!!!
   / Good morning!!!! #106,951
All the walls are good, must be some movement in the ceiling. From the corner of the tray ceiling to the wall (about 2 feet) is the narrowest part of a 40' run of sheetrock. The info I have is there should be an expansion joint if the run is over 30'. I might put extra supports in the attic and try a repair one more time but an expansion joint would fix it for sure.
Maybe a ceiling fan introducing vibration?
   / Good morning!!!! #106,952
weather forecast looks like rain for us and along coast but snow for Roy and others inland. Pace yourself Roy and get grippy.
need to go shut doors on greenhouse. Walking back and forth a couple times a day is good exercise for me. Very cloudy out with rain coming in, no sun to heat it up in there so might as well shut it down for the night. Then open it up next time full sun is out. I planted some rainbow coleus this morning which I found out the hard way does not like hot afternoon sun. Burned up a lot of it last year until I planted the last one left inside, and it absolutely flourished. So now I'll make little four inch pots to take into next months garden club meeting. Actually I'll be up in Pa and miss the meeting but someone will surely take them in for me. Those ladies love the freebies.
   / Good morning!!!! #106,953
My little tractor is an over achiever. Pushed down 3 trees, cut them up and moved them, then filled the stump holes and leveled the ground.
   / Good morning!!!! #106,954
“Randy .. nice truck! Wrong brand ... but still very nice. ” (Rick)
I know, I almost did buy a Silverado!
   / Good morning!!!! #106,955
27F snowing steady getting close to 5" did quick plowing to make it easier for the Mrs. when she came home.
Been ho hum of day here but did get chicken stew and dumplings made...stew not half bad I have to admit. :licking:
Not much plan for this evening might finish block of wood with handle and back stop for the pickup plow to set on.
Enjoy the evening all.
   / Good morning!!!! #106,957
Making progress
   / Good morning!!!! #106,959
49 rain showers move in shut our work down early for the day but did get area damaged regraded and seeded straw and fertilizer as well
   / Good morning!!!! #106,960
One side roofed.
Still needs a trim edge at gutter
And this was transporting some stuff from tractorshed to carport
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 45' Reach, Rear Steer, 60" Forks, 6,699 Hours (A59076)
Gradall 53409-45...
2017 Freightliner M2 106 AWD Terex Commander C4047 Insulated Digger Derrick Truck (A55973)
2017 Freightliner...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
JOHN DEERE LOADER BRACKETS FOR 5000 SERIES TRACTOR (A52708)
JOHN DEERE LOADER...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
(2) METAL WELDING STANDS (A58374)
(2) METAL WELDING...
