Good morning!!!!
   / Good morning!!!! #212,701
Yesterday was a pretty good day for Holly had dinner in best restaurant in Roanoke Alexander’s. A celebration of sorts early birthday dinner. For the bad days this one great day made up for all the bad. Praise God
   / Good morning!!!! #212,702
Good Morning
It’s 52°, overcast with good visibility. Forecast to become partly sunny and make it just over 60.
Yesterday we did manage to get the ERV installed, it was a bit of a project. My proudest accomplishment was mounting the control and finding the thermostat wire that was buried in the wall accurately enough to not even need touch up paint.
The location of the wire is circled in red in the picture that I’m sure glad I took during construction. That was for an alternate location for the heat pump thermostat. The one to the left is for the radiant heat.
I took the radiant thermostat off and looked in that hole with an endoscope to locate the spare, measured the distance with the endoscope cable.
I still need to balance the airflow, it requires a manometer with two ports for differential pressure, mine only has a single port. Good excuse for another tool that will be here tomorrow.
Managed to keep the 3D printer busy all day as well.
One of the projects was this white cap for the vacuum port on the drywall saw to collect the dust without a vacuum attached. It worked well for a single cut out like the one in the ceiling for the ERV fresh air return, but would have to be emptied for every cut if you had a lot to do. Not sure how well it would work if you weren’t cutting overhead.
Today starts with breakfast with the professor, then off to Newburgh to pick up the Citation from the service center.
I have a friend coming along that’s excited about getting a ride in a jet.
After that it’s back to the regularly scheduled tasks.
And the best news is that yesterday, i cleaned up more messes than I made!
   / Good morning!!!! #212,703
Morning all, 54 to 70 and the clouds are thinning
Got about half the decorations out, will do more tonight.
Ground is still pretty hard so will take out the tractor to push in a few t posts.
Back to the day job,
Be well
   / Good morning!!!! #212,704
good morning all
up way too early but sleep patterns a little off lately
Buckeye, great song, thanks.
enjoying an early cup of coffee, lots of projects for today including mowing and trimming the whole place, then washing my rv.
That should wear me out.
since my wife died of rectal cancer at age 55, importance of colonoscopy sure clear to me...as miserable a process as it is.
Now I did not do three days of clear, which apparently I should have. Geez, three days of jello? That's mighty hard to take.
if you bleed or things hurt down there, please please get it checked out.
prep is miserable but the procedure (thank you propofol) is easy.
really looking forward to getting outside today. Should be a nice Fall day in the 60's just getting into low 70's.
need to clean out the veggie gardens too, tomatoes are done and a viney mess. Will pull them all up and chuck in woods.
that probably will wait til tomorrow.
RS, sorry about your hot water heater. Does anyone here replace the anodes or otherwise do maintenance on electric
hot water heater? With my acidic water I'm amazed I have any elements left.
hope you all have a good day.
I used to do anode maintenance on the water heater. The first time I had to haul a 3/4" impact wrench up to get the anode out. After that it went a bit better, but the anodes were going in about eight months and that got old pretty quickly. So, I quit swapping anodes.
I bought a powered anode (Cerro-Tec, now available on Amazon), and it's going on towards fifteen years.
Our water heater doesn't accumulate sediment, but if yours does, I would recommend replacing the cheapo drain valve with a higher quality brass gate valve. I've had a couple of the cheapo ones fail to seal in the past after a single use.
Today is gutter day, with some of the outbuildings getting new gutters with stainless steel mesh screens (wildfire (WUI) requirement now, and no more leaf blowing gutters for me, yay!).
FWIW: I noticed yesterday that the stainless steel mesh easyon gutter guards happen to be on sale at our local Costco, 20% off, but for a package with 36' instead of 24'. They work well here, but at some point if your local rainfall rate gets too intense, water is going to sail across the screens, so it's not perfect.
All the best,
Peter
   / Good morning!!!! #212,705
25 years ago I got seamless gutters put on this place and the first winter the snow load took them off. Called the people I bought them off (they had installed them too) and they said that I had a steel roof, which they knew about when they had quoted me the price and did the job. So zero warranty. I could have sued them, but didn't want to lose the time off work. They have NEVER gotten a recommendation from me.
I understand that gutter guards are good IF you have leaves. I've got pine needles. But now with no gutters I don't have to worry about it.
We've gotten used to the fact that when we go outside in a rain storm we WILL get the back of our necks wet.
Just think, the best season of all 4 is coming soon! The no bugs season! Winter.
   / Good morning!!!! #212,706
"no bug season"
now there's something we all can agree on, and wish for
of course after all the flowers have been pollinated
made about ten trips in from rv unloading stuff, then went and mowed and trimmed and weedeated
the lawn. Was pretty long, took awhile and I'm doubting I'll get to washing the rv today.
Tomorrow looks good.
with my acidic water and lots of sediment, no water heater will last long here, and my landlord for sure is not going
to pay a plumber to change the anode. I'm sure there's nothing but a stub in there.
remember when i got here my nice looking 11 year old oil burner had never been serviced since install.
I promptly paid to have it done and it gets done every two years.
when this water heater inevitably fails, will ask plumber to make sure good shut off valve provided.
   / Good morning!!!! #212,707
dentist appointment went well. Cleaning and X-rays. Some gum recession
Wife was brought directly into the dentist chair since she can not use the waiting room.The chairs are too low and she can not get up. Got all the family updates from our dentist friend. Sold motor home since as she said there was always something that had to be fixed and they were not the handy types that could do it themselves. Instead bought a place in retirement community near Orlando and spending a week a month there
D was elected to the Board Of Directors for a company that she likes. She also started new training in the cyber security field that she will combine with her management and analytical skills
   / Good morning!!!! #212,709
25 years ago I got seamless gutters put on this place and the first winter the snow load took them off. Called the people I bought them off (they had installed them too) and they said that I had a steel roof...
Steel roofs usually require snow guards every 12 feet, or so. We have four staggered rows of them, on our raised-seam metal roof.
I understand that gutter guards are good IF you have leaves. I've got pine needles. But now with no gutters I don't have to worry about it. We've gotten used to the fact that when we go outside in a rain storm we WILL get the back of our necks wet.
Screw the neck... you don't have basement flooding without gutters?!?
I have gutter guards on all of our gutters, and they're great for both leaves and needles. They don't handle the occasional deluge as well as gutters without guards, but they're infinitely better the other 99% of the time.
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
Giyi Mini Side Shift Forks (A53316)
Giyi Mini Side...
2009 Ford F-450 Ambulance (A55788)
2009 Ford F-450...
16' Cattle Guard (A53316)
16' Cattle Guard...
New JMR Skidloader Work Basket (A50775)
New JMR Skidloader...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
