GX390 Flywheel Nut Question
/ GX390 Flywheel Nut Question #1
jbradley
Clarinda, Iowa
JD 4020, JD 430 garden tractor, BCS 948, BCS 732
I recently purchased an electric start conversion kit for the GX390 engine on my BCS 948. My shoulders are complaining about the amount of torque that they have to pull against to get it started. I don't have a socket head that fits the flywheel nut. Does anyone know what size it is? I tried to measure it with calipers, but I can't get them close enough.
/ GX390 Flywheel Nut Question #2
Looking at several parts diagrams for different version of that engine, they all indicate that it's 16mm.
I found that also, but that's the threaded portion. The head is larger.
/ GX390 Flywheel Nut Question #4
So it is, 16 x1.50mm. Since an 8 x 1.25 nut takes a 12mm wrench, it would make sense that this one should be about a 24.
Do you not have any metric sockets, or just a spotty set that omits a bunch of sizes? You could probably run a crescent wrench or some needle nose vice grips down until they were snug and then measure that with the calipers.
It is a 23mm.
I knew it was less that 25, because my 1" socket was too large, and my metric sockets only went through 18mm. I bought a 23 & 24 and then returned the 24. The flywheel is now off.
/ GX390 Flywheel Nut Question #6
Greetings!
Did you managed to install the starter motor. I am also interested in doing so. On the side note, isn't it when you start having problems like hard starting the culprit is usually the valve spacing and need's to be adjusted?
Greetings!
I have the starter installed, but I haven't gotten around to wiring it, yet. I have to make a short jumper wire to splice into the kill switch, as the wires are too short when just disconnecting the butt splice connectors. Fortunately, it hasn't snowed enough here (SW Iowa) to need the snow thrower, but it has been cold enough that I haven't been ambitious enough to work in the garage. It will be warm enough pretty soon.
The installation is not difficult, and only a bit of a PIA. The kit that I purchased on Amazon had no instructions, so I had to surf a bit to find some. The distributor sent me a copy of the wiring setup, only. The punchout for the starter motor required filing all the way around it, and there are a couple of holes that need to be threaded. The cost is significantly less than adding a new electric start engine, and that in and of itself would probably be a bit of a PIA, too.
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2014 Vermeer Vac-Tron MC533SDT Heavy Duty Vacuum Trailer (A60352)
2014 Vermeer...
2019 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A60352)
2019 GMC Sierra...
Pallet fork attachment for mini skid steer (A61567)
Pallet fork...
2016 Ford E-450 Passenger Bus (A61568)
2016 Ford E-450...
