Three point hitch won't lower
/ Three point hitch won't lower #1
Scott in ME
Bolens/Iseki G154
Disclaimer - this is my first tractor with a three point hitch nd the first time I've ever used one. It's a Bolens G154/Iseki TX1300F. I installed a 48" wide snowblower on the back today. All went great and blower does what it's supposed to do, although it's up in the air. The lift raised the blower, but now it won't come back down. There is a lever to the right of the operator's seat. Rearmost position is lift, middle position is down, and far forward position is float. Nothing does anything. When I put it in the lift position, even though it's already lifted, I can hear the engine strain. My knowledge in this area is pretty limited. Does anyone suggest a place to start looking for the problem? Thanks. Here it is the in the up position.
/ Three point hitch won't lower #2
If you look closely around the bottom of the 3 pt lever, towards the seat, you should see a small lever. That's is the down speed control for the 3 pt, so you can adjust the speed that the 3 pt drops, however, if fully closed, it won't let the arms drop.
Here is a picture from the manual. Hopefully it helps.
/ Three point hitch won't lower #3
On some tractors this may be a lever or knob beneath the seat. Also look for a mechanical stop on the three point control. This stop can prevent the lever from moving to its mechanical limit.
Thanks for the help. PTSG was right on. The valve in the photo (with my finger pointing to it) was closed. I cracked it open and the implement came right down.
/ Three point hitch won't lower #6
Awesome, easy fix.
2019 CATERPILLAR 299D3 XE SKID STEER (A65053)
2019 CATERPILLAR...
Trench Box (A64553)
Trench Box (A64553)
INGERSOLL RAND 80 GALLON COMPRESSOR (A65643)
INGERSOLL RAND 80...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
10ft Fork Extensions (A64553)
10ft Fork...
JOHN DEERE 5403 TRACTOR (A65643)
JOHN DEERE 5403...
