John Deere 5525 Blowing fuse
   / John Deere 5525 Blowing fuse #11
I see no one has posted to this thread in 10 years but I wanted to thank everyone for contributing. I have a 5525N that experienced this problem and this thread is how I finally tracked down the problem. I can confirm the sensor, called a Temperature Sensor Part #RE503242, was responsible for a Fuse F1 20-Amp Ignition Switch failure. Disconnecting the sensor meant I could turn the key and try to start it, but even in California the January weather was too cold to start without the sensor. Replacing it solved all my problems. Thanks, guys!
   / John Deere 5525 Blowing fuse #12
Great news
I made a note of this in my manual.
   / John Deere 5525 Blowing fuse #13
   / John Deere 5525 Blowing fuse #15
5325 is the only 5cyl that I know of.
   / John Deere 5525 Blowing fuse #16
Where used part # search on JD parts reveals ""64"" different listings utilizing the same 5 cylinder engine block. Partial list of models is shown below. All I noticed was 2 tractor models being 5225 & 5325 along with some skid-steer applications
   / John Deere 5525 Blowing fuse #17
5525. does this tractor have the five cyl engine?
Four cylinder turbo.
They use the part on all sorts of engines. Very common part for my dealer.
   / John Deere 5525 Blowing fuse #18
Exact same problem on a 5093E coolant temperature sensor kept blowing 20 amp ignition fuse, almost drove me insane.
   / John Deere 5525 Blowing fuse #20
What did you do to fix the problem?
Replaced the exact same part# that was described earlier in this thread. Temperature sensor/switch part#RE503242 , seems to be a common problem in several different models.
UNUSED FUTURE XGJ 40" HYD ROTARY TILLER (A57193)
UNUSED FUTURE XGJ...
Giyi 48" Mini Excavator Root Rake (A56469)
Giyi 48" Mini...
UNUSED WOLVERINE TD-13-36R 36-48" TREE DIGGER (A57193)
UNUSED WOLVERINE...
UNUSED FUTURE CAT 305 EXCAVATOR RIPPER (A57193)
UNUSED FUTURE CAT...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
