6400 jerky clutch
/ 6400 jerky clutch #1
stoneridgemb
ste rose
allis 7040
this is a JD 6400 fwa, power quad with right hand reverser. Just as the clutch is about to engage, the tractor jerks forward. it had a broken spring in the modulation valve and I also changed the piston but it did not solve the problem. If I quickly release the clutch the tractor pulls away smoothly. what do I look at next? Tractor has 12000 hrs, is clean and works everyday
/ 6400 jerky clutch #2
Does tractor shift forward to reverse and reverse to forward smoothly without using the clutch? If so, I suspect the clutch valve may be sticking in the bore. you need to remove the front cover on the transmission to inspect it. I had one that link 49 was worn crooked and was binding on guide 31. Replacing the link and attaching pins 27 and 30 cured the problem.
/ 6400 jerky clutch
It usually shifts smoothly but once in a while it is choppy. Seems better since I changed the spring+valve. I'll try checking the items you mentioned. do I need to drop the oil in tranny?
/ 6400 jerky clutch
TRANSMISSION FRONT COVER - ST237081 is where I'm looking at JD parts.com. Is the linkage external?
/ 6400 jerky clutch #5
A buddy of mine had the same problem on his 5400 2wd 4-5 years ago. After contacting the local independent JD mechanic, he told him it was more than likely the clutch pack needing replaced. Not from wear, but from rust/corrosion in the clutch pack not letting all the plates and disc's release evenly, causing the tractor jerk, when releasing the clutch pedal. As I understand, your not able to rebuild the clutch pack, so a new unit is required.
Being my buddy was working a lot of overtime at that time, he decided to let that mechanic do the work. I don't recall the total bill, but remember the clutch pack was around $650 at the time.
/ 6400 jerky clutch #6
Looking at JD parts catalog, it looks like you have to remove the front cover to get to the parts he mentioned (27, 30, 31, 49). I would say you have to drain the transmission.
I am not sure what you mean by is linkage external. It looks like arm 20 to shaft 22 to internal part 23 which connects to link 49. Arm is external rest are internal. I assume clutch cable connects to arm 20.
/ 6400 jerky clutch
If I pull off the front cover can I expect anything to come apart? any springs or valves that will be between the cover and rest of tranny or are they secure?
/ 6400 jerky clutch #8
JD 5400 has a dry clutch while 6400 has a wet(hyd operated) clutch. Comparing operation of each type clutch is similar to comparing "apples to oranges".
/ 6400 jerky clutch #9
I have NOT done this job, BUT looking at JD parts it only looks like there is plate with gaskets both sides behind the front cover.
IIRC the cap screws that hold the drive shaft in (4 front, 4 rear) are "one time use". They have serrations on the under side of the head.
Key 10 and 11 in the drawing.
/ 6400 jerky clutch
Been running tractor waiting for a local tech to make time to look at the clutch valve, noticed the tractor does not jerk when it's in reverse. I can back up smoothly to hook up implements etc.. but when I go fwd it jerks on takeoff. Is this still likely the clutch valve?
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
2016 Chevrolet Express 2500 Cargo Van (A64556)
2016 Chevrolet...
E-Z TRAIL 500 GRAIN CART (A64277)
E-Z TRAIL 500...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
213137 (A64276)
213137 (A64276)
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
