Rear Blade Rear plow blade carnage
/ Rear plow blade carnage #2
Were you "pushing" with the rear blade;that's a no-no;designed to pull not push.No trip somethings got to give.
/ Rear plow blade carnage #3
Did your dealer sell it to you or was it an internet purchase? Sorry I dont have any experience with this brand. Very unfortunate to have this happen in snow season :(
/ Rear plow blade carnage #4
Looks like a cheaply made blade. Thin material and crappy welds. We can clearly see that a full bead of weld had no penetration at all.
I think you may need a heavier duty blade for the Branson. Those tractors are very heavy and put lots of traction on the tires, so the implements need to be up to the task at handling all the forces.
/ Rear plow blade carnage #6
Yikes! Sorry to see that. Had to have been a rock. What speed were you going and was it down a steep grade?
/ Rear plow blade carnage #7
"Heavy Duty" everywhere except where the strength is needed. Looks like a flesh wound. Tack welded but not 'welded'.
/ Rear plow blade carnage #8
HF 90a glue gun. Could be a warranty issue, carefully document poor welds. If not, cut and repair as neccessary. Hopefully not with a glue gun, but an actual welder. On the bright side, better the damage happened to the blade, rather than the tractor.
/ Rear plow blade carnage #9
Oh crap.... And I was seriously contemplating purchasing that particular blade/design in 48 or 54 inch for behind my SCUT... As a alternative to the cheap crap at TSC...
I would send pictures and complaint directly to BE corporate (yes it's also chinese import) ....
Dale
I got the blade with my new tractor from the dealer. Really happy with the Branson so far. I didn't even look at the rear blade as it was not on the tractor. Dealer said he would warranty it. Just have to bring it back.
Not pushing backwards or anything. Going pretty slow. Less than 5 mph. Didn't even feel a thing. That Branson with the cab is a tank.
/ Rear plow blade carnage #13
Whatever...... I would consider a few more $$$ and a better rear blade. However, the way it's stove up - looks like it was being used to push.
/ Rear plow blade carnage #15
Easy peasy, so get another, just the same.
I like forty year old blades, for this reason. And they are dirty cheap. Heck, I have one I never use, that I was going to make into a grader and got it for FREE.
/ Rear plow blade carnage #16
Even with my heavy duty Rhino 950 - I simply reverse the blade, drive forward. If the idea is to simply smooth things out. It's just too easy to hook up on something and cause damage.
/ Rear plow blade carnage #17
Good for the dealer to take it back. I'll bet he will be better informed on how to match up a rear blade to the tractor weight from now on.
/ Rear plow blade carnage #18
Looks like a junk cheap blade. Quick googling shows maybe 190 pounds for the 5' blade??
IF so, you have WAY too much tractor for such a cheap and light blade if you are serious about working it in the dirt.
/ Rear plow blade carnage #19
It really doesn't take a lot of weight to create a lot of inertia with a bit of speed.
Funny thing is. A guy could try a thousand times to hook something with the corner of a blade and not be able too, but have no trouble doing it (first time) by accident!
/ Rear plow blade carnage #20
I hear Rolls Royce even has a warranty now because of some problems they have had in the past with their vehicles.
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
Demco Lowboy Trailer (A65563)
Demco Lowboy...
2014 RETESA 210BBL CRUDE TRAILER W/ PUMP (A65643)
2014 RETESA 210BBL...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65054)
(INOP) 2013 MACK...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
