I folded my Quick Tach plate
   / I folded my Quick Tach plate #11
I would go as far as saying that design could be dangerous.
Especially if you are under the attachment being held by the ssqa plate....................:laughing:
   / I folded my Quick Tach plate #12
Or it drops it's load and attachment in front of you on the road at speed.
   / I folded my Quick Tach plate #14
I agree it's a sub par design.
It's not uncommon to see them that aren't integrated side to side. But they are built much, much stronger on each independent side.
   / I folded my Quick Tach plate #15
The SS quick attach is NOT a great nor robust design to start with but it certainly requires that it's individual componants remain intact. There is no redundancy.
   / I folded my Quick Tach plate #16
Agree.
My JD 5055e had a 1 inch (approx.) rod running side to side which could rotate. It depended entirely on the attachment to maintain alignment.
No issues
   / I folded my Quick Tach plate #17
Agree.
No issues
Using yours as an example, look how close the top angle bracket of the hitch is to your cylinder pins. Go back and look at the OP's. No comparison.
   / I folded my Quick Tach plate #18
If one side of the QA could operate independantly of the other, I would lose my mind, as I do on my JD 640 loader that does that. As it is, in uneven terrain, I have trouble attaching a ridged side to side SS coupler and it always amazes me how it can be that hard. You would think if you get one side in, the other side not quite engaged and lift up, it should all line up. But it doesn't.
   / I folded my Quick Tach plate #19
I'm betting I could bent a loader arm before my SSQA would ever bend or twist
   / I folded my Quick Tach plate #20
The OP's system cannot operate independently. That's not even an issue in it's design. The issue is the vertical distance from the top angled bracket down to the cylinder pins. Go back and look at the first pic again.
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
MAHINDRA 3650P TRACTOR (A58375)
MAHINDRA 3650P...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
