RTV 1100 Transmission problem
/ RTV 1100 Transmission problem #21
The dealer called to pick up the RTV 1100. Then called again 30 mins later to not pick it up because the Tech tested it before coming out and found the same problem. So after 800 dollars we are back to square one
Maybe it is the clutch packs like the other site talked about?
/ RTV 1100 Transmission problem #22
I wouldn't pay for missed diagnosis, only pay for labor and parts that fix the problem.
Agree I should not have to pay for the missed diagnosis.
/ RTV 1100 Transmission problem #25
It sucks, but that is not realistic in this day and age. Things are just too complicated, change too quickly and besides, the dealers/mechanics didn't engineer or design the thing. Someone has to pay for their time and overhead.
/ RTV 1100 Transmission problem #26
To a certain extent yes but why should he be paying for their incompetence? Things are complicated but if you do not have trained people with the knowledge to repair the machine you should not accept the work.
/ RTV 1100 Transmission problem #27
This where I have problem with Kubota, the service shops don't really seem up to the task. They should have a traveling expert to assist. Like Ford does with my GT350 engine, You wait till factory guy shows up, they don't let the dealers open the engine.
/ RTV 1100 Transmission problem #28
Shops should have a library to hold the service bulletins that assist the mechanics. I'm thinking there would be a bulletin that explains this issue and repair. Does this dealership even keep the bulletins and put them where all the personnel can read them? Does Kubota have a service rep for the area? Were they called? Are they competent? The OP is paying the shop to diagnose a problem correctly and repair it. He shouldn't pay the entire bill for the mechanic to try experiments on his RTV.
/ RTV 1100 Transmission problem #29
People just have never seen the inner workings of a dealership. One guy who is long gone had "factory" training on some particular piece of equipment, and now they advertise "factory trained techs". It's crazy to think that every tech is trained on every component of every model they deal with. So mostly, a dealership has more resources than the average guy but they just muddle their way through a lot of repairs.
I have had car dealerships unable to tell me where my fuel filter was on a fairly new p/u truck and once even a Buick dealer didn't know where the battery was located (under the seat). So if you think they know more complex stuff, I think your're kidding yourself.
I have never charged my customers to learn while I fix their stuff unless it's been agreed upon.
/ RTV 1100 Transmission problem #30
We are "armchair quarterbacking". We have no idea what was specifically spoken between the owner of the RTV and the Dealership.
This is a tough situation.
Hopefully it'll work out.
The dealer had requested assistance from the Kubota experts is what I was told. Then they called and said the fix was to change the suction hoses and oil and filters plus the diagnosis time adding up to 800 dollars. I was happy that the fix was external to the transmission so they went ahead with the repairs. As you know it did not work. They told me they had done a lot of pressure testing on the transmission and driving around to experience the shut down of the transmission. So what is next? Will sure try to not have to pay for failed repair but they have the RTV so not much leverage unless they agree.
/ RTV 1100 Transmission problem #32
Yep, I understand.
I have compassion for the mechanic when he has no solution and contacts the manufacturer. The contact person there is probably sitting at a computer desk typing in what information he's given and restating what the computer offers for a solution.
I'm in a situation like that now with a new JD grader. The JD "expert" is now just throwing parts at it hoping something sticks. Difference in my case is it's all covered under warranty. Still frustrating. Frustrating for the mechanic tech also.
/ RTV 1100 Transmission problem #33
Make sure you tell them that's it's the 770 Grader and not the Tractor they need information on. I always thought that kind of odd, the model numbers that is.
/ RTV 1100 Transmission problem #34
If the mechanic doesn't know the difference I'm screwed. :)
/ RTV 1100 Transmission problem #35
Kubota has regional mechanical reps which visit regularly to dealers shops. Ask them if they don't have one "coming".
So the Kubota dealer finally concluded that the drive/pump unit is the problem. According to them it has to be replaced as a unit costing 4200 dollars for parts alone. The RTV 1100 is a 2012 cab model with 1100 hours and looks like new since it has always been garaged but putting over 4000 dollars into it probably does not make sense. Other than buying a new one what options do I have?
/ RTV 1100 Transmission problem #37
Options? You might get a second opinion for one. After the first $800 failed attempt at repairing the issue, I sure would be hesitant on throwing $4200 at them so they could try again.
The conclusion is that the pump does not maintain adequate pressure when the oil gets up to full temperature. With colder oil the RTV performs as normal. What I meant with options is how to repair it. New pump on Messick site lists for 3800. There does not seem to be any internal parts available. There have been forum write-ups about changing the swash plates in the pump. Likely that is the issue due to warped swash plates in the pump. Maybe they discontinued selling internal parts.
There does not seem to be any rebuilt transmission available. A few used ones on Ebay but that will be risky.
Maybe using it as is and limit it to shorter trips. Sell it buy a new one perhaps. Dealer gave me a loner RTV 900 and it drives nicely. However I will need the cab like the RTV x1100. Are there any model updates coming from Kubota on the RTVs? Could wait for a while if updated models are about to be released.
/ RTV 1100 Transmission problem #39
If you've got proof of all the required maintenance I would go after them for repair on defective design, manufacturers often have hidden warranties. Or offer you a very good trade in rate.
Bought a new RTV X1100 today. Will be delivered end of week. Moving over mirrors, radio, screen for window, Boss snowplow to the new RTV
(3) 295/75R22.5 TIRES (A62131)
(3) 295/75R22.5...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
UNUSED KJ 40'X20' STEEL CARPORT SHED (A62131)
UNUSED KJ 40'X20'...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2001 CHAPPARAL B/STOCK TRAILER (A62130)
2001 CHAPPARAL...
