Reliable pull behind mowers?
/ Reliable pull behind mowers? #1
cold1313
Gold Member
Northern, Ohio
Kubota M4D-071 Kubota F3990
I was wondering if anyone here uses a pull behind mower for an ATV / UTV / Side by Side whatever you want to call it.
I have some steep slopes on my property (around a pond, etc.) that I am unable (i.e. unwilling) to risk with my tractors and mowers. I can travel these areas with my Polaris Ranger without any worry or pucker factor. It's not a weekly mowing type of thing but maybe every month or so.
So far I have kept this down with weed whips, etc. Many, many hours doing so.
Unfortunately the only options I have found are from Swisher. The more expensive units ($1,600 - $2,200) appear that they'll work on paper however I don't get a great feeling on build quality, durability etc. I also wonder how the 2 wheeled version would do going along a hillside and if it would want to slide down the hill. I can crabwalk the unit with the Ranger, just trying to think ahead.
Unfortunately the used ones are complete junk in my area and there is no place for me to look at a new one.
Cutting this area every month or two would primarily be heavy grass and stalky weeds. I'm sure there is the occasional tree starting to try and grow but I don't plan on taking out saplings with something like this.
Any recommendations?
I hate to spend a ton of money on a unit, especially if I'm not sure how well it'll work. (Swisher) Has to be durable enough to handle the slopes and bumps along with a pressurized oiling system in the engine to operate at those inclines.
/ Reliable pull behind mowers? #3
We had one years ago we pulled behind a Honda 300 4x4 ATV. It lasted 3 years. If the land is flat, meaning no ruts or holes, and the grass is not too thick, it should work ok. If you want a nice, clean cut, prepare to go slow, about 2-3mph tops.
That's what I was afraid of....
/ Reliable pull behind mowers? #6
This is ideal for your described usage. It will cost you approximately $1,800 but has other application usage beside mowing around the pond.
59" Gas Flail Mower, PK-AT145E | Betstco Sales, Parts, and Service:
/ Reliable pull behind mowers? #7
Now I do not know your budget, but check out Ventrac. They have 8 wheeled compact machines that can mow hillsides and also have other attachments.
Ventrac is made about an hour from me. I just need something for a few "smaller" areas. My other equipment can handle the rest.
/ Reliable pull behind mowers? #12
I had a 44" pull behind Swisher that i liked a lot. Mine was a finish mower and worked well on the lawn. It could scalp and even stall the blades if it got high centered when cutting. They do make a trail cutter version that has blades more like a Bush Hog mower that might be better suited to your needs.
Mine was built pretty well. The 10.5 hp motor that it came with seemed to be a little under powered in tall grass. After a couple of years I I found a good deal on a 15 HP Kohler electric start motor and it worked great. Iused that Swisher about 10 years till i bought a big zero turn and it was no longer needed.
/ Reliable pull behind mowers? #13
I had a Swisher tow behind rough cut style but sold it after a couple years. It was a little underpowered, required a large turning radius and it's hard to keep a constant travel speed with a thumb throttle on an ATV. Often it just folded the tall stuff over with not much cutting action. DR made a two wheel rough cut one but looks like they've dropped it and only produce a 4 wheel one.
/ Reliable pull behind mowers? #14
I had a 63" made by Agri-Fab. It was a 4-wheeled version. I used it for a few years behind a Sears Suburban Garden Tractor. It did a great job cutting up until the point we had some work done with a dozer. The dozer found a metal T-post. It buried it except for about 2 inches or so. Somehow the front of the mower deck made it over the post but I caught with the blade. Messed that mower up. Bent the blade, shattered one of the 3 jackshafts, bent the belt pulleys, and the pulley on the bottom of the motor. I replaced everything that looked hurt. Still ate belts every few hours. Spent more on parts then I spent on the thing originally ($1500). Ended up selling it, saying I was only selling the motor, everything else was just a gift. I had bought the New Holland and wasn't needed as much any longer even though I really wanted to pull it behind the New Holland off-set.
/ Reliable pull behind mowers? #15
Sounds like a very rough experience. :(
/ Reliable pull behind mowers? #17
Do we have any reviews of this PK-AT145E Flail Mower yet??? If you seen or used one, please tell us about it.
/ Reliable pull behind mowers? #18
I've got a 40" titan ATV flail mower being shipped at the moment, hoping it gets here this week. I'll update with some pics and let you know how it works out once I fire it up!
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
3 Brake Drums (A62613)
213141 (A64276)
213141 (A64276)
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
24" BUCKET (A64277)
24" BUCKET (A64277)
211297 (A62131)
211297 (A62131)
