Welding aluminum
/ Welding aluminum #1
Gomer pyle
Murfreesboro, TN
John Deere 5090E
I am a hobbies/farm repair. I have an older Snap-On (rebranded Systematics) power source (100% duty cycle at 300 amps) with a Miller wire feed. It does an awesome job. It is my first welder.
I have a project coming up, where I need to weld a bunch of aluminum. I may never do anymore, but having a tool and knowledge is always handy.
Per manufacturer, in order to put a spool gun on my power source, I have to get a different box($1200 for controller and spool gun). This setup will only work on my machine. I don’t mind the price, but keep thinking about the age of my machine.
Any other ideas/opinions? I’m not against another machine but don’t think I would sell mine. The project coming up would be mostly 1/4” square tubing with a little bit of 3/8” flat plate.
/ Welding aluminum #2
For $1200 you can get something like the Lincoln 180 mig machine AND the Lincoln 100SP spool gun.
If you can step up to the Lincoln MP210 that is a nice machine. They also make the 180 in dual voltage 120/240, and or with TIG.
I tend to agree with you- spending that much on the old machine probably isn’t the best investment.
/ Welding aluminum
I do fear the duty cycle with the newer smaller machines. I have no patience. Lol.
/ Welding aluminum
I do have a Lincoln 140 I bought to use with a generator for portability on the farm. I believe the 100sg will work on it but I can’t find any info on material thickness.
/ Welding aluminum #5
This may not help at all...but I had to weld some aluminum and some of these alumafix rods you can order from eBay. Thinner aluminum I use a propane touch, thicker I used oxy/acetylene like I was brazing.
As I say, it all depends I'm sure at what level this project is for, strength, professionalism, etc.
/ Welding aluminum #7
You could always try running aluminum through your current feeder and gun. Teflon liner, U-groove feed rolls, 45 degree neck, 10' gun and 5356 wire. It's doable.
/ Welding aluminum #8
If the job pays for the tool and you still make a decent profit id call it a wash. That spool gun will always come in handy you'll probably use it more than you think. Going from 300 amps to 180 don,t make good sense to me but what do I know I'm a gluten for old transformer machines not a hole heap load to break.:drink:
/ Welding aluminum #9
This is what I would do, running a spool gun on aluminum can be a ***** for a beginner and you won't get far with those little Lincoln machines on 1/4'' and 3/8'' aluminum.
/ Welding aluminum #10
If you are looking to buy new equipment and expand your capabilities,have you considered tig? Can you run tig off your power source? Another consideration is the ampacity required for 300 amp transformer. I believe you can buy a multi-purpose inverter machine and accessories for $1200.
/ Welding aluminum #11
I'm also wanting to weld aluminum and improve my welding skills so I'm here to learn.
thank you all for sharing!!
/ Welding aluminum #12
Look at a MIG/TIG/STick inverter machine. My Miller Multimatic 200 is a smooth welder offering both a MIG (using a spool gun) and TIG process on aluminum but there are less expensive options.
/ Welding aluminum #14
Why not pick up some Aluminum wire, install a teflon liner, make sure you have pure Argon hooked up, crank up the wire speed and give it a try as Yomax suggested.
Op may be surprised just how well it may work.
Very little cost and you have the power to weld way thicker Aluminum than any newly purchased 200 amp welder.
If the mig cable torch length is ~12 feet or less on the existing welder- it makes even more sense since you will not be pushing the Aluminum wire an excessive distance. my :2cents:
/ Welding aluminum #15
When I bought my Miller 210 (transformer) I got the spool gun accessory on a package deal at a hard to pass up price. I have yet to break it out for a couple of reasons... okay maybe three. First I haven't had a 'job' for aluminum welding... second, I don't have the Argon tank... and three, I am a bit chicken. Am looking forward to the day... when I can dedicate some time though.
/ Welding aluminum #16
Add me to the list of trying the above. I would NOT bother buying a contactor and spool gun for your current old machine.
/ Welding aluminum #17
Hmm. Start gathering aluminum scraps or drops from your metal supplier or nearby shops. Buy an exchangeable bottle of argon.
Post here and we will kick your butt on the “chicken” issue. We’ve all been there.
You’re welcome, Mark! Btw I thought you had the Miller 211 tranny* ?
*welder talk referring to transformer welder. Do NOT google “tranny”
/ Welding aluminum #18
Here is a 125 cu/ft argon cylinder 125 cu/ft 1% Argon Tank Welding Gas Cylinder CGA 58 - FULL - - Amazon.com Your spool kit should have come with a regulator. Get a separate steel brush to be used just for aluminum. Aluminum MIG spool gun 100 or 200 is just about the same as the steel MIG process only the feed speed is way faster and it is more critical to back-draw the end of the weld to avoid a pit as pits in aluminum welds can more readily be the start of a crack in welds subject to vibration (like on trailers).
/ Welding aluminum #19
It's Key to turn up the wire speed when 1st starting. Turn it up til it pushes you away and then back it off until it runs. Saves on burn backs and bird nests. Larger wire is much easier to lean with as well.. Good Point !
/ Welding aluminum #20
Post here and we will kick your butt on the 田hicken issue. We致e all been there.
Youæ±*e welcome, Mark! Btw I thought you had the Miller 211 tranny* ?
*welder talk referring to transformer welder. Do NOT google �ranny�/QUOTE]
Oops typo, yes 211. And yes someday I will subject myself to the TBN welding gauntlet when I break out the spool gun. No I will not google tranny. Thanks for all the advice.
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
BULLDOG INDUSTRIAL 9000TB GAS GENERATOR (A64281)
BULLDOG INDUSTRIAL...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
Trimble 2050 Display Screen (A64119)
Trimble 2050...
