Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,090
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I have found a schematic from the IH 1066 Hydrostatic;
https://cdn.compknowhow.com/carterandgruenewald/wiring_diagrams/IH 66 SERIES.pdf
The + from starter (battery) goes to plus on Amp meter, the minus from the Amp meter goes to alternator "B".
It looks to me that the Amp meter shows the lights current from the battery when the tractor is not running and key switch of , and the amp meter shows charging amps only when tractor is running
Then may I conclude that it's showing me what it should be showing?
That would seem to fit what I'm seeing.... key/engine off, lights on meter showing nothing because lights are riding on battery power. Engine running, it shows alternator trying to charge battery and when the lights are on, (powered by the battery) the alternator is putting out more power to feed the battery.
If I moved (whichever wire is feeding juice to the lighting system) to the OTHER Ammeter post, would that shift those items from the battery power to the alternator power?
Big question..... "does it really matter???"
