Ammeter question....
/ Ammeter question.... #41
An ammeter will tell you if the battery is charging or discharging, but it will not tell you how charged the battery is, so if the battery has a bad cell and is at 11 volts after starting the tractor and continuously charges but never gets above 11.5 volts, everything will look good on the ammeter, but the battery may not start the tractor next time you go to use it.
Aaron Z
Bingo. Or Yahtzee. Depending on your preference. :)
That right there is my primary reason for preferring a volt meter. I am primarily told the condition of my battery. The fact that it also possibly reflects the condition of my charging system is bonus.
I would wire everything back stock the way it was. It's been that way nearly 50 years working fine. Back when that tractor was designed all you really cared about was engine running above idle ammeter shows charging. Running needle moving left discharge means a problem with alt/gen, regulator or wiring problems.
Heh...that's impossible.
Though the engine ran, not much else worked when I bought it (Tach worked and temp gauge)
Most of the wires behind the dash had rotted sheathing, many many of them were dangling, not attached to anything (they might have been snipped at one time but I don't know that)
I bought new Ammeter though I don't recall why... been too long.
So Ammeter, ignition, and the entire wiring harness have been yanked out and replaced with new.
TODAY, virtually everything works..... all exterior lights, dash lights, shift illuminator light....everything. I now don't think anything is wrong nor, miswired here. I think I was just working under the wrong pretense on how it should work.
I hope to later today, drag both batteries out there and hook things up to verify.
Even if it's wired wrong, about the only thing I was scratching my head on was the Ammeter.... machine runs fine so I'm going to have to prove to myself that something is wrong, otherwise it's going to stay as is. It's 1,000% better than it was prior to the rewire.
drove me nuts seeing all those dangling wires.... I didn't know if I was a bump and shifted wire away from smoking the harness by shorting a hot wire. In the end, I don't think I was as my fuse was also destroyed (and got replaced with new). One nice thing about putting the new harness on.... though the instructions could have been a bit more clear, I had the existing wires in place to give me some ideas of how to snake them through places. Just took it one section at a time..... started at the alternator & did the front of the machine.... then the dash section, then the fender lights. Since the 1066 evidently came stock with a SINGLE light in each fender, and this tractor has dual lights, I had to do a bit of splicing to bring both into the circuit.
My expectation on how this would work WAS:
Start machine, that costs you some battery power. So, as machine is running, the ammeter SHOULD show NEGATIVE and as the battery returned to a full charge, the needle would tend towards zero.
What I EXPERIENCED: Start machine, needle jumps to (let's say) +1.... turn lights on (bigger drag on system) and the needle goes to (let's say) +3 HOWEVER, the more it runs, the more I expect it to DWINDLE DOWN to zero indicating that the system isn't now charging the battery as much.
So though I think I "got it", I got it from the wrong perspective. I think I was describing more the workings of volt meter rather than ammeter. Reasonable???
/ Ammeter question.... #44
Let me change the subject slightly......
I have an ammeter. What if instead, it was a volt meter.
As a practical matter, what's the benefit of one over the other? (if any)
IF voltage is above resting voltage of battery then system is (alternator/generator) is supplying sufficient amperage to charge battery and supply electrical needs. ITs in a charging state
IF voltage is below resting voltage of battery then system IS NOT getting enough current from Alternator/generator to charge battery and supply system needs... Its in a discharge state
Lets say if battery is in resting state reading is 12.88 volts (just measuring battery voltage with everything off) .
Now start engine....
IF voltmeter is reading something like 13.85 or more volts, then system is charging.
IF voltmeter is reading 11.95 volts (or anything less then the above example of 12.88 volts) the system is in discharge state.
Keep in mind actual battery voltage is a result of chemical reaction inside battery ... We say a typical automotive battery is 12 volts but actually it some want more (something a bit over 13.2 volts...
Also helps to know some about batteries...
Car and Deep Cycle Battery FAQ, Battery Manufacturers and Brand Names List, and
Dale
/ Ammeter question.... #45
A volt meter is simpler and cheaper to install. With the voltmeter, you can locate it anywhere and all you have to do is run a small wire for sensing the voltage to any convenient spot. With an ammeter, you have to install heavier wires from the point you want to measure to the meter. The longer the run, potentially you can have a larger voltage drop to the system. Also, when you get into 100+ amp systems, like a lot of automotive systems today, that can be problematic. A solution to this would be the use of a shunt type ammeter, but it also has its weak points. For those that have been around ammeters for a long, long time, when you start to see a steady increase in charging current for no apparent reason, you will recognize that there is a problem developing with the battery.
That is why in high amp systems, a voltmeter is easier and cheaper.
Yes, once you are use to looking at ammeters, it is easy to see something is wrong.
/ Ammeter question.... #46
Interesting stuff!
I can see where the volt meter would be of benefit..... actually, I think I was looking at the operation of the ammeter from the viewpoint of how the voltmeter would work as I've been looking at it as an indication of my batteries health/charge. Looks like instead, I was monitoring the charging systems health!!
Do they make a dual purpose gauge (same size) that does both?
Yes, but it has to be wired correctly to be of any use...
Be careful because most digital voltmeter with ammeter have very small/limit range for measuring amperage....
https://www.amazon.com/Voltmeter-AiTrip-Accuracy-Automotive-100V-10A/dp/B07KFVD11B
https://www.amazon.com/Spartan-Powe...PK82F21YCHZ&psc=1&refRID=J4PPN180DPK82F21YCHZ
Dale
/ Ammeter question.... #47
Nope, ALL the ammeter tells you is which direction power is going through it and how many amps are going through.
So, machine off, if you put a meter on the battery it would read 12.5V.
You start the machine (that does not go through the ammeter), alternator wakes up and starts charging the battery. The ammeter reads let's say +25A because the alternator is adding 25 amps to the battery, the volt meter reads 14.8V.
Turn the lights on and the voltage momentarily dips to 14V, then comes back to 14.8V, when the voltage dips the ammeter will also swing back towards 0A, then go back to +25A until the battery finishes charging, at that point the voltmeter still reads 14.8V and the ammeter will read 0A.
Turning the lights on (assuming that the lights are on the alternator side of the ammeter) should not change the ammeter reading UNLESS the alternator is maxed out and can't keep up with charging the battery and supplying power to the load (from the lights, etc).
Aaron Z
Just got back from starting the tractor.
Side note.... as I understand, the stock alternator (in amp size) was no longer available.... so instead of having (let's say) a 90 amp (50?) alternator, I have a 110 amp alternator. Whatever the original size in output was, this new one is slightly more. AND all the lights except for the dash lights were replaced with LED's so the way I see it, I have more juice available from the alternator however, I have collectively, smaller demand.
(don't know if that matters to know or not)
Anyway, just went out, put both batteries in (two 12V long skinny type verses two 6v).
The lights, all of them, work totally as expected EVEN WITH THE KEY OFF. Turn light switch, and they come on.
During this non-running time, I was staring at the (again, brand new) ammeter and though the engine was OFF, it didn't budge at all. Didn't slide upwards, nor did it slide downwards. It was as though it was simply dead.
(side question..... all lights are now LED's, would they draw enough power like that to make it show??) I would deduce they must show since they show the change from "+1 to +3". Interesting.
Started the engine and AT IDLE, the ammeter just sat there, pegged at zero. Once I revved the engine a bit, THEN it perked up and went to (let's say) +1. When I turned the lights on, then it went to (let's say) +3.
Turning key off/back on had no effect on the meter, even while engine running.
However, after reading all this info (which is fantastic by the way), I'm now curious if maybe I don't in fact, have a wire hooked to point "B" instead of point "A"....
I don't think I've EVER witnessed the meter showing anything less than zero and typically, it's at the +1 mark because I don't do anything yet requiring any lights.
/ Ammeter question.... #49
From those symptoms I would say that your lights, ignition switch, etc are definitely on the battery side of the ammeter vs the alternator side where it should be.
Aaron Z
/ Ammeter question.... #50
This is "concept" on how a voltmeter and/or ammeter should be wired....
Does not matter if car or truck or tractor or bus or gas engine or diesel... Electrical are electricals...
Dale
/ Ammeter question.... #51
Your Amp meter must be in the charging system and therefore reeds alternator output Amps.
( On my tractor the Amp meter is in the wire from battery to ignition switch, and should read amperage going in or out of the battery ( except for starting ))
The Amp meter is an "indicator" and does not have to be very accurate.
Amp meters can be wired in different on tractor makes or models.
I assume that the Amp meter was important when tractors still had a DC generator, and the Amp meter showed charge. A tractor running idle, with lights on, could drain the battery.
Alternators usually keep up with all the factory installed lights and accessories and a volt meter gives a better indication of the health of the system, for the people who know how to interpret the reading.
Usually a light is enough to to show if the system is working or not.
/ Ammeter question.... #52
Well almost.... A voltmeter would work that way if you started the engine and then immediately turned it off. That is, it would show that the battery is able to put out slightly fewer volts than it could before you started the motor. It might have dropped from 12.3 to 12.2 for example. However, as soon as the motor is started, the voltmeter is reading the average voltage in the entire circuit. That includes the alternator output voltage which is now spinning and charging the battery with something a little bit more than 13 volts. So the voltmeter will show the average of the slightly depleted battery and the alternator charging at a higher voltage.
Sometimes it helps to thing of the two aspects of electricty as being similar to a flow of fluid. Voltage is like the pressure (psi) in the hose, and amperage is like the total quanitity of flow (gallons per minute) of the fluid.....or of the electricity.
You measure voltage by putting the meter in parallel with the circuit. That means you measure voltage with one wire from any one point and the other wire to frame, which is considered to be a stable "ground". One side of every single circuit in your tractor is always connected to grounro voltage in a tractor is not usually no volts. It is just not enough pressure to be useful.
You measure amperage by putting the meter in series with the circuit. Basically you cut a wire and insert the meter. This is how amperage of flow is measured, and just like any kind of flow it can flow in one direction or the other.....which is why zero is in the center of the ammeter. It is not only showing you the amount of flow, it is showing you the direction.
Rscotty
/ Ammeter question.... #53
My apologies.
I rewired the entire tractor (brand new harness).... IF I recall the instructions correctly, there was a wire that came back from the alternator and another wire that came up from the starter/solenoid. As I recall, it bridged these two items. What I was wondering at the time was do the wires go "A/B" or "B/A" and did I have them backwards. I put them in as per the instructions.... I just had an uncertain feeling in the back of my head.
Well... I thought I still had the harness installation instructions. If I do, I can't find them yet.
I don't know WHICH wire that may have come from (presumption from the alternator) but I'm 99% sure the other end went to the battery.
I have found a schematic from the IH 1066 Hydrostatic;
https://cdn.compknowhow.com/carterandgruenewald/wiring_diagrams/IH 66 SERIES.pdf
The + from starter (battery) goes to plus on Amp meter, the minus from the Amp meter goes to alternator "B".
It looks to me that the Amp meter shows the lights current from the battery when the tractor is not running and key switch of , and the amp meter shows charging amps only when tractor is running
Than there could be a situation that current is drawn from both battery and alternator, than the reading does not making sense. (full battery and low RPM ?, )
Good stuff.....thanks to all.
I think, well, I KNOW I'm not going to touch this during winter!!! (don't like cold). I think I'll perhaps dig into this more once spring arrives. I don't want to say this for sure, but I think there were several wires that attached to the rear of the meter. One large one (I presume 12g) and if I recall, a smaller one. I don't recall if there was one smaller one on one side or if both sides had a second, smaller wire.
What I DO have floating in the back of my head as a distant "is that what I recall happening....." is that I had some issues fitting the wires onto the screw lead coming out of the meter.
If THAT is where one puts it "on the battery" verses "on the alternator", then that would make some sense to me as getting the meter wired up was something I had to fiddle with and if I recall, had to take apart and do again. It's possible that I crossed something.
None the less.... today, not a worry for me. Come spring, I might see if I can trace down the smaller wires.
Again, thanks to all.
/ Ammeter question.... #55
The schematic for the IH1066 is available online, and looking at it, it's complex especially for the year (1971 to 1976 I believe it says). Add to that cut, disconnected wires, bulbs replaced with LEDs, etc. and it's a mess.
I was going by initial post "I did a full harness rewire last winter/spring. (new harness, new ammeter / instruments, new lights, batteries, ignition switch.... virtually EVERYTHING except for the tach and water/oil info. I even replaced the button for ignition and the other button for the ether."
So I assumed completely rewired back to factory stock.
Again, I'm thinking about 45 years ago, that tractor. In use you're only concerned with a few things when looking at gauges...rpm, does it have oil pressure, is it charging, etc.
Back in the shop you can check batteries, voltage, etc.
Like lots of cars back then (and pre 70s) had "idiot lights" key on...they all light. Start motor...all should go off. You don't care running if oil pressure is 30 or 45, or if battery voltage is 12.8 or 14.1, you just care that you have pressure and it's charging.
We collect old cars. My wife has her first car, a '55 Chevy her Mom bought new. Original drivetrain and wiring...not one LED light anywhere. My thought is whatever you have, tractor, car, truck it is what it is. If you want to "upgrade" (I hate that word)...just buy new.
My opinion is you have a good tractor, I'd just have it back like it was. Like schematic Dale shows, everything starts with the batter(ies). Battery + positive to ammeter + positive. Ammeter -- negative side to ignition switch ("everything else" so to speak).
/ Ammeter question.... #56
Great explanation Fuddy. I've often heard the water/electricity comparison and believe it to be valid.
I'd agree to put the tractor back like it's been since inception.
So,,, makes me wonder,,, why do they now use volt meters?
"So,,, makes me wonder,,, why do they now use volt meters?"
Complexity IMHO.
With computers, complex circuitry, voltage is more important and critical. A new tractor a meter with "D" and "C" on it wouldn't mean or tell you much.
What I was told in electronics school another lifetime ago was all meters are ammeters. All! So you had a multimeter with lots of voltage, current, resistance ranges...but one ammeter. To measure current, you switched in different resistors across meter (shunts). To measure DC voltage you switched in different resistors in series so the meter was measuring current flow through the resistor (voltage = current times resistor). To measure resistance the meter had it's own battery, again switching in resistors so (resistance=voltage/current).
Airplanes ammeter had the shunt resistor near battery, two small wires off of it to ammeter in cockpit. Safety...so if meter failed it didn't matter, you still had the low resistance shunt in the battery circuit.
Trivia...
/ Ammeter question.... #57
I left out multimeter to measure A.C. voltage meter had diodes to convert a.c. to dc then measure. Multimeters use precision resistors for accuracy.
/ Ammeter question.... #58
Complexity IMHO.
Trivia...
My offroad buggy uses a Volt Meter. It comes in handy when doing serious winching. If I run the system voltage down too low the computer will shut off the vehicle. I can watch the Volt Meter and know when I'm approaching that issue. An engine stall because of low voltage while hanging on a winch cable is not good.....
/ Ammeter question.... #59
Volt meters began showing up on tractors in the very late 1970s and early 1980s. Fact of the matter is, the OPs 1066 was replaced by the 1086 which included a voltmeter, not an ammeter in the instrument panel.
/ Ammeter question.... #60
Yeah.. Dropout voltage in my Jeep is about 9 volts... 100 amp alternator can not keep up with winch...Fortunate large Odyssey battery will come back to life if it sits about 15 minutes to allow me to start Jeep...
Dale
John Deere 672GP (A64126)
John Deere 672GP...
2001 16 Ft. Wellcraft Boat w/ 2000 19 Ft. Boat Trailer (A61574)
2001 16 Ft...
Lot 602 (A62613)
Lot 602 (A62613)
2022 EZ-GO ELITE...
6' Bush Hog (A62613)
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
