Hello from Georgetown Texas
/ Hello from Georgetown Texas #11
We will send you the water down the river we don’t need.
I saw a little trickle the last couple of days. The winter-rye might get another chance within the next couple weeks
/ Hello from Georgetown Texas #13
This is the weather for the rye to really take off, light rain this morning moderate temps.
I was really hoping to aerate before overseeding the pastures but I didn’t get a chance. I bought a turfvent 3 point hitch 48in aerator to go behind my kubota g1900 but I still gotta rig it up some how.
/ Hello from Georgetown Texas #15
Stumbled across this forum while searching for correct zert fitting on the upper pivot of the 3 point on a Kubota Tractor. Turns out there is also a little feed for the Kubota Lawn Tractor G1900 I just purchased. I work with a JD 5103 and a Kubota M4700. Hoping to get effective use of TR3 implement.
Up here in Missouri we spell it zerk, I get accused of enough stuff without people thinking I zert. LOL
I think I actually referred to it as a zerk fitting too back in the day of the Marine Corps.
Still haven稚 replaced that zerk fitting. Does someone make a board template/figerouter to size the zerk fitting? Like the boards to choose the correct bolt size in the hardware isles.
/ Hello from Georgetown Texas #18
Maybe it just needs to be taken out and the zerk and the joint cleaned with a cleaning solution- like a carburetor cleaner. If the zerk is defective just take it to a hardware store they should be able to match it.
The top of it is broke off. I think maybe I’ll get it with an easy out tool..? Maybe tap it out with a small punch.
/ Hello from Georgetown Texas #20
Welcome to the forum.
Blue Diamond 72" Bucket (A60463)
Blue Diamond 72"...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
AGROTK YC-32G Horizontal Band Saw (A60463)
AGROTK YC-32G...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
