New 2020 Kiotis
/ New 2020 Kiotis #2
They also are coming out with a revised version of the ck2510. It will now be a CX and will have tilt steering, side by side pedals instead of treadle, and toolbox, and I believe some other factory options like armrests and linked pedal. IMG_3700.JPG
/ New 2020 Kiotis #3
I like the tires on that new Kioti...Those must be the new R14s I have been hearing about.
/ New 2020 Kiotis #4
/ New 2020 Kiotis #5
Anyone hear when these new/revised models might be hitting dealer lots?
/ New 2020 Kiotis #7
Looking forward to seeing the specs on the CX2510, what motor, hydro GPMs, loader and 3 point lift. I like the separate pedals versus the treadle. Allows you to put your boots flat on the deck. I wonder if the manual will have a shuttle versus traditional gears. Would love to see an 8x8 with shuttle shift on this size tractor.
/ New 2020 Kiotis #8
I’m almost positive it will have the same specs as the ck2510, just cosmetic changes.
/ New 2020 Kiotis #10
Very interested in seeing confirmation on the CX would love a surprise like a new Hydro with H/M/L :)
And maybe 1200-1500 lbs of loader lift! I know, I'm dreaming. I just really want a small CUT that can still lift a lot (and handle the heavy rear ballast to do it safely, of course).
/ New 2020 Kiotis #11
H/M/L transmission would put the icing on the cake for me, but I don’t think they have any plans on that right now.
/ New 2020 Kiotis #12
Check out the LS MT225e. The loader has 1600# lift at the pins, 2700 # breakout force. 3 point lift is 1800#. Not bad specs for a small CUT. It also has a 3 range transmission.
/ New 2020 Kiotis #18
Whoa, hadn't looked into this cx2510 hst yet. pretty small cut, but the KL2510 loader still lifts almost 1100lbs to 88" off the ground. Anyone know is the bucket is quick-tach? it's gotta be, right? Also, which size mid-mount mowers will be availible?
Given the price disparity of CKs to Kubota Bs/Ls, I don't see how this 2510 wont come in at least a couple grand cheaper. And 84 month 0% financing now too....
/ New 2020 Kiotis #19
Yes, SSQA on the bucket. 60 inch MMM available. Factory 3rd function option. I called in to my local dealer a couple days ago and said he put in his order for CX series on Monday. Said he should have them in a week or two.
And on that loader lift stat, Kioti historically has set their loader lift numbers lower than reality. Take a look at the pump flow numbers. 11.4 G/min is by far more than any other tractor in it's class.
/ New 2020 Kiotis #20
“ 11.4 G/min is by far more than any other tractor in it's class. “ except for LS... 12.6 gal/min. For the MT225E.
429888 (A61165)
429888 (A61165)
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
Trailmobile Van Trailer (A63118)
Trailmobile Van...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2022 Kuhn FC4461 TCD MoCo (A63116)
2022 Kuhn FC4461...
