I use it in everything I own (CX5; F150; 60 Impala, mowers, saws, blower, etc.) and never buy anything with ethanol in it unless it's an emergency.
The miles driven between fill up would drop by 1/4.I have been an ASE master automobile tech, Michigan master automobile tech with 18 years as a drivability tech in a Ford dealership.
Octane is the resistance to burn. The higher the number the more resistance to ignite. I have seen well meaning people who used high octane fuel tow their vehicle into the dealership in very cold weather because it will not start. The engine is typically flooded badly the oil is contaminated with fuel, many times the plugs will need to be replaced. My advice is to use the fuel recommended by the manufacturer.
Do not use alcohol blends in seasonal equipment. Alcohol blends start to break down in 30 days it has very poor shelf life.
-Todd
Stick or auto? We have auto. I dislike the way it interacts with the slow timing of the throttle-by-wire. I step on the gas pedal, nothing happens, so my brain says "step harder', but in that instant of brain-to-foot time, the throttle catches up with my initial step, and it ends up pushing it too far, the car accelerates faster than you want, and it jerks your neck. I know there's some tunes out there that can clean that up. Just deciding if I want to go that route.
All the studies I have ever read including car owner manuals say that it is a waste of money and could actually be detrimental to the engine to use any higher octane than what the OEM recommends. This does not include engines that have been made into dragsters by highly modifying them like dalola did to his truck.
I have also read you get a benefit in the F150 both the eco-boost and the 5.0 of using higher octane and even E85. The problem is does it offset the cost? Does slightly more power and slightly better fuel mileage offset the cost? I doubt it.
