Egon
Epic Contributor
Fat pine spills and fat pine kindling work well for starting a fire.
I have an Extech MO50 about $44 on eBay. It has 2 pins and digital display and seems well built. Parent company is FLIR, well known. You can spend about as much as you want on a moisture meter but I do not see doing that. $44 gets you above the junk but below wasting your money. The outside of a piece of wood will be dryer than the inside but is still a good indicator. If the outside is over 18% (my cutoff) the inside generally is too wet to burn without creating creosote. Ideally you would do a fresh spilt of a large piece and test the center and it should be under 20%.
Our exterior air moisture stays above 80% all winter which lets Doug Fir (our most common wood) stabilize at around 14 to 18% moisture after 2 years under cover. Split at the start of the 2 years, not at the end. Wood dries much better split.
Moisture Meters | Extech Instruments
I've never been able to figure out how our firewood is supposed to dry out to the 15 - 20% moisture content target, when the humidity levels stay 40 - 80%.
Someone want to explain the physics to me?
Pine cones also make great fire starters.
I personally found, that at times the propane torch is not enough to get the SS liner heated up to get a draft started. I have tried. So I am unconvinced, that for my installation, a bulb would work. Best option is just to use something what burns (guaranteed) and with little smoke. I actually used to love the gell type fire starter, but have resisted spending the money. Hate when you spend money to save money. But opening all the doors and windows in the middle of winter to try and get rid of the smoke and not have the smell get into the furnishings, isn't good either, never mind uncomfortable.
But yes, the wood situation is rarely a priority and done in Ad Hoc fashion. Most wood burned is just cut down DEAD standing ELM, into three foot logs, throw it on the porch by the front door and that is what we burn in the fireplace that weekend. Very satisfying work and not much handling. Not very efficient for heat, but not much work went into it either. And it doesn't just fall down and rot.
