Buying Advice B2650 vs JD 3033r
/ B2650 vs JD 3033r #1
Alpinestars114
2014 Kubota L3940
I had a 2012 Kubota L3940 that I recently sold so I've been on the looks for a new tractor. I have will be using it to maintain my driveway it's pretty long put in about 1 acre of food plot. I will also be doing other things around the property. The l3940 was simply to large tore my yard up with ag tires and so forth. Now I'm stuck do I buy a new B2650 or a used 3033r I just don't want to end up with someone's problem. I'll post the link to the JD
John Deere 333R 4x4 Tractor w/ Loader & Forks - Greenhill Farms Equipment, Inc
/ B2650 vs JD 3033r #2
I don't see the JD as being much smaller or tearing up the yard less than the L series. Tires being the only issue. But it's not like the JD is running turf tires either.
/ B2650 vs JD 3033r #3
I agree, the 3 series JD is bigger than a B series Kubota. I’d look at a 2 series JD.
/ B2650 vs JD 3033r #4
Is the drawbar missing on the Deere?
/ B2650 vs JD 3033r #5
JD is bigger than the 2650. FWIW a new 2650 probably isnt much more than that used JD, that alone if we are looking at those two only I would take the Kubota. I have 4 acres, about 400ft of driveway, and honestly probably have mild use and my 2650 is more than what I need.
/ B2650 vs JD 3033r #6
The 3033R bare tractor weight is 3086.
The B2650 bare tractor weight is 1664.
Your old L3940 bare tractor weight is 3483.
If tearing up the turf is your concern these numbers should settle the question for you.
/ B2650 vs JD 3033r
Awesome I have 8 and a 600 fr drive.
/ B2650 vs JD 3033r #8
We get 150in of snow a year and have used a walk behind, craftsman rider, and now the Kubota on 400-450ft of driveway. The kubota has by far been the best obviously, but i can tell you with snow im not sure a 150hp tractor would get rid of snow any better. Bigger you go the bigger the blower or blade i guess, and if you push snow bigger is better.
as for the 2650 Kubota has it at 1786lbs. Dealer said my rear filled tires added 300. my front blower weighs 500lbs plus the hook up stuff, so lets say 600, and the cab I have is another factor, Guess that thing weighs probably another 3-500lbs. So im confident all said and done my winter set up weighs over 3k, I have an inclined driveway with R4 tires and have yet to engage 4x4.
/ B2650 vs JD 3033r #9
No but with a BIGGER (150hp) tractor, you can drive pretty much where you want, not just where you have cleared the snow. It's a nice option to have.
/ B2650 vs JD 3033r #10
No I get that, just making the point that in terms of snow clearing and snow clearing, they all kind of due it the same, but like you said environmental factors might be different for different folks. But with that said he was concerned about his lawn. And like me I dont want to drive anywhere I want anyways. Sometimes bigger is not better
/ B2650 vs JD 3033r #11
Well, I had a 3940 with loaded industrial tires. Sold it when I stopped hunting. It was used to supplement a 85 hp tractor that did the grunt ground engagement work. I bought a 2650 a few years later with unloaded turf tires. Both are open station. The 3940 was a substantially heavier tractor with the loaded tires. If the ground was at all moist, it would leave tracks. The 2650 with mmm doesn't cause any issues in the yard but it will tear the grass with the front tires if I cut the wheel sharply. However, it is pretty big for mowing the lawn. I also have a bx2200 that I was going to sell but I decided to keep it as it is so much more agile around trees and landscaping so the bx does the mowing and the 2650 everything else. I would categorize the b2650 as an estate tractor. It's great for mowing small fields, lifting things, maintaining a large garden, and other gentlemanly things. It too light in my opinion without loading the tires and I will load mine after we move in about a year. I wouldn't think about lifting anything over 250# w/o ballast. I don't have a gravel drive right now, but I plan to use the 2650 with tnt and some combination of box blade, landplane, and blade when we move and have a 1000 ft gravel drive.
/ B2650 vs JD 3033r #12
So you bought which tractor????
/ B2650 vs JD 3033r #14
Congrats!!! We need pics of course.
/ B2650 vs JD 3033r #16
I think it's a great choice you won't regret. Still loving mine especially with a six foot blower out the back for the white stuff.
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
2021 Deere 35G (A64126)
2021 Deere 35G...
(4) 29/11-15 Dirt Track American Racer Tires (A64127)
(4) 29/11-15 Dirt...
2015 New Holland 560 Round Baler (A63688)
2015 New Holland...
New/Unused AGT YSRT14 Mini Skid Steer (A65583)
New/Unused AGT...
