Hydraulic Filters from Power Trac
   / Hydraulic Filters from Power Trac #21
Good point
   / Hydraulic Filters from Power Trac #22
I bought 6 hydraulic filters when I was down at Tazewell and noticed how they didn't have the neat little power trac logo anymore. These filters tell you the manufacturer, part number, etc. I priced these filters on the web and it looks like they go for 30 to 40 dollars. I'm going to continue buying them from PT, just so it gives them a little bit of business. I appreciate the fact that it's a small American company of about 30 employess, probably not making allot of money but enough to make a living and have a sense of pride (the healthy type) in there workmanship.
Thanks for posting. I am currently using the Wix 51551 cross reference mentioned in the sticky thread. A little research on the part number you posted shows that the W in the part number means it is capable of filtering out about a half liter of water. Feel like I need to order place a filter order with power-trac ASAP!
   / Hydraulic Filters from Power Trac #23
Hmmm. Not sure about this. As I understand it water filtration oil filters are much more restrictive. I am far from an expert on this so ymmv.
   / Hydraulic Filters from Power Trac #24
Just to add to the confusion, anyone know how long a hydraulic filter can last in a low use environment? I Have another hydraulic machine that gets used enough to keep the oil dry but maybe only 20 hours a year and the manual says change every 200 hours.
   / Hydraulic Filters from Power Trac #25
20 hours per year won’t keep oil dry unless you live in an arid climate or store the machine in a controlled environment. 3 years would be my limit on filter life.
   / Hydraulic Filters from Power Trac #26
I am also no expert, but the mfg literature makes it clear that is what the W is for in the part number, and makes no mention of being more restrictive. See pages 6 and 15 of the pdf below:
https://www.mpfiltricanada.com/files/products/in-line-strainers.pdf
For reference the MP Filtri part number is CSGW-100-P10A
Amazon wants $55 for this and I haven’t found it anywhere else. $22 at Powertrac seems like a bargain.
   / Hydraulic Filters from Power Trac #27
Amazon wants $55 for this and I haven稚 found it anywhere else. $22 at Powertrac seems like a bargain.
Just realized that OP has a PT-1430 vs my PT-425 so please disregard my comments about pricing. However question still remains about whether the OEM PT-425 filters remove water and whether that is desirable.
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2018 CATERPILLAR...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
New Holland Basket Rake (A56438)
New Holland Basket...
2014 Nissan Altima Sedan (A59231)
2014 Nissan Altima...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
