New L2501 is here
/ New L2501 is here #1
gregfender
Gold Member
Marion, NC
Kubota L2501 HST
Now I just need to get it dirty.
/ New L2501 is here #2
congrats on your very Nice new orange machine!
/ New L2501 is here #3
Very nice. I have been getting very interested in these lately. Not sure If I would buy another B or one of these next time around. The L2501 is still small enough I can mow with it.
/ New L2501 is here #4
Did you get rear remotes? I was curious how they are set up on those as far as the control levers. Do they have the extra slots in fender for them?
/ New L2501 is here #5
Nice tractor and congratulations! Looks like you are set up to do some work!
/ New L2501 is here
No rear remotes. But I will probably get them later. I am assuming they would have to be fender mounted.
/ New L2501 is here #8
Now that's what I call starting the new year off right :thumbsup: congrats.
/ New L2501 is here #9
...assuming they would have to be fender mounted.
Not if you get the factory kit, which is expensive but a very clean install. It goes into the slot next to the 3 point lift handle.
I mounted a 3 spool valve above the FEL controls. One for the grapple, one for the hydraulic top link and one for the hydraulic side link. I just prefer it in front of me.
Some have mounted it below the FEL controls... personal preference.
/ New L2501 is here #10
OK thanks for info. Can you get one or two factory installed rear remotes on these?
/ New L2501 is here #11
/ New L2501 is here #12
You can have 1, 2, or 3 valves stacked together with the OEM setup (which I installed on my L3200). Certain positions can only accept certain types of valves due to room for the lever to travel. I have one float/detent valve and one dual acting valve. They also offer a continuous flow valve (detents to on).
/ New L2501 is here #13
So you can still have 2 or 3 rear remotes if you also have power beyond for a backhoe correct?
/ New L2501 is here #14
Not familiar with backhoes but Power Beyond is just a fancy name for the high pressure hydraulic line. There is constantly flowing high pressure hydraulic fluid circulating through that line. Everything that taps into that high pressure line (in series, one after another) has to allow that high pressure flow to the next spool (valve) until the fluid is dumped back into the tank.
So (on open center systems) the FEL, extra valves, and the backhoe (that are not self contained, meaning it uses the tractor's hydraulic system to pressurize the pistons) has to let the fluid circulate freely...
So the "2 or 3 rear remotes" will also have to have power beyond ability.
/ New L2501 is here #15
Yes, in fact the rear remotes are part of the power beyond loop too, just like a backhoe would be.
On the stock tractor, the power beyond loop goes straight to the 3-pt hitch.
If you add a front loader, it is inserted into the loop before the 3-pt hitch.
If you add rear remotes, they are inserted into the loop after the front loader and before the 3-pt hitch.
If you add a backhoe, it is inserted into the loop same as the remotes -- between the front loader and the 3-pt hitch.
The 3-pt hitch is always last in line and it provides a return to the reservoir.
/ New L2501 is here #16
Thanks for that s219. That made it very easy to understand. I had always wondered if you had to give up a rear remote with a backhoe. I don't have a backhoe, but I think I may get one on next tractor.
/ New L2501 is here #17
Depending on the manufacturer, the BH may use the remotes. My LS with a factory BH, plugs into one of the remotes that has a detent. But, I ordered my tractor with 2 pairs of remotes. I know of people that have the same tractor, the same BH, but no remotes. Their BH has 3 hoses, mine only has 2. They have ports that are dedicated flow for the BH.
Again, it varies By manufacturers. Do some research.
/ New L2501 is here #18
On the Kubota L series (and most Kubotas I know of) the backhoe is plumbed in independent of the rear remotes.
/ New L2501 is here #19
Really there is no difference flow wise to tapping into the PB loop or plugging into a rear remote that is locked open. You can use a bungee or rope to keep the valve/lever open if it's not detented. In both cases you get full flow & pressure on the inlet hose & the outlet hose goes to tank. Pumping full pressure to the wrong side of the hoe valve can be bad for some of them. Just have to make sure you get the hoses in correctly in either case & push the lever the right way if its tied into a remote
/ New L2501 is here #20
On mine, it does not matter which ports the hoses go into. It will just change the direction of operating controls on the BH. To correct them, I just move the remote lever (detent) to the opposite direction.
This could really be helpful for someone who is dyslexic :D
