Did you get rear remotes? I was curious how they are set up on those as far as the control levers. Do they have the extra slots in fender for them?
Not if you get the factory kit, which is expensive but a very clean install. It goes into the slot next to the 3 point lift handle....assuming they would have to be fender mounted.
I don't know for sure but read this: https://www.tractorbynet.com/forums/hydraulics/378651-kubota-rear-hydraulics.html...Can you get one or two factory installed rear remotes on these?
So you can still have 2 or 3 rear remotes if you also have power beyond for a backhoe correct?
Yes, in fact the rear remotes are part of the power beyond loop too, just like a backhoe would be.
On the stock tractor, the power beyond loop goes straight to the 3-pt hitch.
If you add a front loader, it is inserted into the loop before the 3-pt hitch.
If you add rear remotes, they are inserted into the loop after the front loader and before the 3-pt hitch.
If you add a backhoe, it is inserted into the loop same as the remotes -- between the front loader and the 3-pt hitch.
The 3-pt hitch is always last in line and it provides a return to the reservoir.
Thanks for that s219. That made it very easy to understand. I had always wondered if you had to give up a rear remote with a backhoe. I don't have a backhoe, but I think I may get one on next tractor.
