Sliding doors for Pole Barn
/ Sliding doors for Pole Barn #21
I had a 56' x 40' built about 8 years ago with 20 ft. sliding doors 14 ft. tall at each end. The doors are actually 2 10 ft. doors sliding out. I've never had any problems with the doors and never had a mouse in the building.
Sliding machine shed doors are not mouse proof. :)
/ Sliding doors for Pole Barn #22
The way mine were installed securely against the concrete floors have kept the mice out. The doors are all steel and pull tight against the walls also. I can only say a mouse has never been in this barn. I have another barn with overhead doors and mice are using that barn.
/ Sliding doors for Pole Barn #24
I built the door I think you're describing just this fall. I had a 20' by 40' pole barn with 4 bays 10' wide and 20' deep, and I put up roller based track from TSC on the inside of the beam at the entrance, and built a door 12' high by 10' wide so it rolls past one of my support poles on the inside. I bought four light 2" by 2" steel tubes. One runs horizontally just under the track trolleys and is bolted up toward them on short hangers. There are 4' high T-111 siding panels bolted to that tube, and there's another tube bolted along their bottoms, so it's a 4' high panel with steel tubing edges. Then I built a similar one 8' high along the bottom. I long clamps to draw things together when the weight was more than I could handle. I think this whole door and track assembly cost about $600 or $700.
/ Sliding doors for Pole Barn #25
I live in a similar climate as the OP;no way I would use sliders.My new pole barn got a 12'x10' over-head+an opener.Just pull up with the tractor or sidexside and hit the button.Look down the road;do you want to be fighting a sliding door in ten years?
/ Sliding doors for Pole Barn #26
Nothing better than snowblowing and being able to hit the button to open the door and back in without having to get off of the tractor...
Aaron Z
/ Sliding doors for Pole Barn #27
I needed two 20 ft. wide x 14 ft. tall openings. I couldn't find affordable overhead doors like that.
/ Sliding doors for Pole Barn #28
^^ I'll need two 8'w x 8'h and one 6'w. No way I could afford rollup OR sliders by any prices I've seen so far. Plan as of now is to make double 4' swingers for the 8 footers. Haven't decided yet on the 6 footer.
/ Sliding doors for Pole Barn #29
Not sure where you are located, but 8' wide doors run $200-400 on Craigslist around here:
2 8x8 doors for $400 each: Garage Doors - general for sale - by owner
Garage Doors - household items - by owner - housewares sale
6'x8' roll-up door for $300: Rolling curtain door - materials - by owner - sale
Aaron Z
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
Deere 350G LC (A53317)
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
2019 KENWORTH T880(INOPERABLE) (A60736)
2019 KENWORTH...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
RK25 PERFORMANCE SERIES TRACTOR (A62130)
RK25 PERFORMANCE...
