Mowing 72" mid mount mower
/ 72" mid mount mower #1
joes_427_vette
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
Currently looking to purchase a mower for attachment to a 955. Actually found four within a hundred miles. Some are without attaching hardware, others stored outside in the rain and snow. I did find a 72" from a 4700 that is in very good condition, stored inside, used only several years. I am aware the 4700 attaching mounts will not be the same but if the mower pto drive are in the correct location allowing it to be lifted properly. I ran into this going from a 455 to a 4110. I have made mounts and attachments in the past. ( the fun part of adapting ) Just curious if the basic shape will allow for a transformation.
Are any 72" decks " drive over " for mounting ? Another fabrication addition idea I would consider. Sliding a 400# mower under a tractor is not my idea of an easy attachment process.
Thanks, any hints, ideas, or opinions helpful. Anxious to get the " new to me " 955 out of storage and in use.
/ 72" mid mount mower #2
I looked at a few pictures on line and they don't look like a drive over, but I'm not sure. My current JD is a auto connect but my previous Kubota had a 60" deck you have to slide out side ways. It wasn't fun but it wasn't to bad either if you did it on concrete. You just turned the anti scalp wheels sideways and slide it out. It took a little back and forth to get it out. On my Kubota connecting the drive shaft was often the hardest part.
/ 72" mid mount mower #3
I have a no longer used 72" JD mid mower with brackets etc. I'm in Mid Michigan. Where are you ? Could meet partway ? PIC00026.JPGPIC00024.JPG
Used 2 seasons. Doesn't play well when also haying (On and off and on and off, ...) I have the belt covers off in the pictures but they come with it. There are still some deck lift hinges still on the tractor, but I would remove them to be included in the sale.
I now have some experience with freight shipping via. R&L Carriers. But, I'd prefer you see it in person. Used on a JD 1070.
I have a no longer used 72" JD mid mower with brackets etc. I'm in Mid Michigan. Where are you ? Could meet partway ?View attachment 633013View attachment 633012
Thanks for the offer. I have 5 decks for sale within a hundred miles of my location, central Wi. As in your case 3 of the 5 have no correct mount ( for a 955 ) so buying them or fabricating would be the alternative. The remaining two, one is very expensive and the other stored outside. I have many choices that don't require shipping which would be expensive and require crating. I am in the knowledge state trying to figure mounts and correct fitting base.
/ 72" mid mount mower #5
I had an770 with 60" Belly mower. Quite the complicated set up. That mower didn't actually travel on the ground but was always suspended. The wheels are only so it doesn't scalp.
I don't especially like belly mowers. You loose your ground clearance. And the tractor has considerable compaction and can chew up turf in tight turns. I still look after that belly mower having sold it to a neighbor. Taking it on and off is a major PITA. I lift the front of the tractor up with a crane or loader, but there is virtually no way to reach in there and get your hand on the PTO to slide it off. The mower is in the way.
/ 72" mid mount mower #6
I've not used a belly mower on a tractor. I bought a 72" Agmate rear discharge finish mower a few years back and love it. Very easy to connect/disconnect. You just have to be aware of it trailing behind you.
I am going to have to do some maintenance to it this year. I replaced all the wheels last year. One of the wheel frames has loosened from the deck and the bolt/nut is frozen. The looseness has caused it to start rusting between the metal from rubbing so I'm gonna have to cut the bolts out, repaint, and replace the bolts.
If the John Deere 72" stamped deck is anything like the 54" I don't think you will be all that happy with cut quality.
Purchased a vary nice 72" MMM today for $300.00. It does not have the correct attaching pieces for a 955. Modifying the existing mount is in the future. Checked the bearings and belt. The angle drive is full of oil with no play from top to bottom . I would venture to say the drive belt is expensive as it is twice as heavy as the 60" deck.
I was impressed. This deck is huge and weighs a ton. Truly heavy duty built . Its a shame they have a very poor paint process ( electro - static ) I read with no primer. The belt new is probably 150 or more. Anyway the challenge is on to make it fit.
/ 72" mid mount mower #10
Where do you get that information?
When I stripped my 455 for paint. I spoke to the Deere dealer who related they did not have the paint. There was zero primer on the metal parts and paint was peeling in places. Take a look at some used tractors that are a mass of rust when not stored inside.
I was told the surface was cleaned, statically charged and sprayed. I can also scrape paint off the deck and it is shiny with no hint of any metal primer, metal etch or other.
Next your going to say it is like modern house paint, primer and paint all in one. I have redone several tractors, same story. Zero primer.
/ 72" mid mount mower #12
If it's a crappy paint job that's peeling off, sounds more like powder scab.
I would rather have two coats of paint than one primer and one coat of paint.
Could be just horrible prep, probably no degreasing. Mowers take such a beating. Clippings are corrosive and people don't clean them so you get the grass in there like a sponge holding the moisture, and they always seem to have places for water and filth to sit.
The problem is paint doesn't adhere to bare metal. Primer has properties that etch into metal. The only difficulty in some cases is the metal is so smooth ( sanded with 1,000 grit or finer ) there is no surface " bite ". There has to be some abrasive grain in the metal to hold and lock the primer down. Even SMC and fiberglass require primer. Its a common practice in agricultural products to paint over rough welds and unprepared surfaces. As long as it leaves the dealers lot its your responsibility.
In 1978 I purchased a F-100 Ford truck with an orange color paint. Primer was visible in surfaces through the thin coat of paint. The factory rep, Arcell Bishop, looked at the paint and stated it met Fords level of criteria for surface coatings . Not waiting for the blisters of midwest rust I sold the truck two years later never considering another new Ford product. He didn't solve the problem but I did.
/ 72" mid mount mower #14
I have to disagree with you completely. If paint doesn't stick to bare metal, then primer doesn't either. And I can generally scrape off the primer with my finger nail which is much harder to do with a paint coating. Do as you like. I have painted equipment for a long time and forgot about using primer a long time ago.
This is why they are called opinions and practices. Working in a body shop part time any seminar with paint products will agree with my assertion. Common sense also in play here. Paint will adhere for a time period but it will be short lived with discouraging results. Do what works for you. I will not polish metal to brilliance and expect paint or primer to bind to it.
I don't imagine you use paint that costs in upwards of $800 a quart ( $2900 a gallon ) on your projects so failure on your part amounts to $7.99 a quart Rustoleum. I don't like repeating expensive failures so I will stick with my method of operation. Its time to move on. Sorry I disagreed with your professional beliefs and practices.
/ 72" mid mount mower #16
joes.. you are losing credibility the more you post about this.. just sayin...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
2012 Chevrolet Sonic Sedan (A61569)
2012 Chevrolet...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2012 DRAGON 130BBL VAC TRAILER (A60736)
2012 DRAGON 130BBL...
