Do any 3 pt hitches provide downforce?
/ Do any 3 pt hitches provide downforce? #1
SmallChange
New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
I just got to wondering -- are there any three point hitches that can be driven downward, as opposed to just allowed to fall? Using my ripper and my auger, I often wish I could force them down. In the case of the auger I'll hang weight on the boom sometimes. Positive downward force would be a nice feature. Not that I'm going to buy another tractor to get it right now. I was just curious.
/ Do any 3 pt hitches provide downforce? #3
When you use your auger, if you have a friend with a FEL, have him put MINOR down pressure with his bucket on the top of your auger. Not too much, cause you'll break a sheer pin by forcing the auger to do more than it's capable.
/ Do any 3 pt hitches provide downforce? #4
The bit that came with my County Line auger has a screw on the end that pulls it right into the ground. The screw part was available at Tractor Supply last time I looked. I once had an auger attachment that went on a chainsaw. It didn't have a screw, the literature said it was supposed to shave the ground or something similar. What it did was sat on top of the ground and spun. I got rid of it and bought a clamshell hand digger that worked better.
/ Do any 3 pt hitches provide downforce? #5
Very few tractor models -- usually specialized Ag setups -- can provide downforce on the 3-pt hitch. I believe you can still get that option on some larger Deere models. But it's not typical for compact tractors aside from some older oddball models.
/ Do any 3 pt hitches provide downforce? #6
The newer JD 4000R series tractors have 3pt down pressure as an option. As far as your auger, just get a hydraulic down pressure kit for it and you should never want for down pressure again. ;)
Mine's a County Line also, and it has the screw too. My soil's just difficult. River bank gravel cemented together with clay. Clamshell hand diggers do nothing, and even a railroad pick or a digging bar has difficulty. I've used large masonry bits to start my holes....
/ Do any 3 pt hitches provide downforce? #8
Some post augers offer down force as an option. Problem with down force on a ripper is if down force could be applied traction to pull ripper would be significantly lowered as DF was applied
/ Do any 3 pt hitches provide downforce? #9
Boy oh boy! You've really got it rough. I hope you find something that works.
In another thread a few folks around here put me onto some special augers including smaller and stronger ones. I'm sitting tight until the need reaches the $$$ threshold. Which might not be all that long....
/ Do any 3 pt hitches provide downforce? #11
I was thinking of just getting a hydraulic auger to put on my loader then it would be easier to keep it plumb and apply down pressure.
/ Do any 3 pt hitches provide downforce? #12
I do this. I have a 10" auger that goes 4' down, I can get 4' using the loader method SLOWLY.....
/ Do any 3 pt hitches provide downforce? #13
The thing not mentioned, or I missed it is that you weight your tractor for traction. Down force modifies/negates....would modify/negate some of that and it could be a problem.
However, the top link (3rd member) is readily used to cause implements like 3 pt disc harrows to level out on the field so that both sets of blades cut the soil as are required by the conditions.....that's down force.
/ Do any 3 pt hitches provide downforce? #14
If you offset either the digger or the drawbar, you might be able to use a small 1 way cylinder with a chain to pull the auger down. I've used a cable on my bucket with a snatch block on the drawbar to 'encourage' the auger to go south. I leave the bucket on the ground and curl the bucket up to apply the cable force like a winch would.
After all is said and done though, a bucket of water, a sharp auger point and long, sharp auger teeth make enough difference to not need the extra downforce.
/ Do any 3 pt hitches provide downforce? #15
Generally no. Some older Belarus tractors do.
All new MTZ/Belarus 900 series have down pressure from the factory, or as inexpensive option (about 300$).
Those are 84-105 hp models, available in USA/Canada.
What power tractor do you need for your application ?
/ Do any 3 pt hitches provide downforce? #17
That is a pretty cool post hole digger option!
Thanks for posting that picture!
/ Do any 3 pt hitches provide downforce? #18
How effective is that?
My Danuser PHD has that kit, but I’ve never used it, or needed to. Biggest problem here are the bowling ball size rocks you may find. Hit or miss.
I hooked up the hoses once and things made funny noises, later discovered (I think) that only one hose is suppose to connect to SCV, and other hose is suppose to directly drain back into hydraulic fill port (and not have a connector on it).
Now I can’t remember or figure out why 2nd hose had to go to fill port and not other SCV port? I understand 2nd hose is the return line from a relief valve on kit (i.e. cylinder is single action), but why couldn’t 2nd hose still be connected to SCV?
Is this how yours is?
/ Do any 3 pt hitches provide downforce? #19
I bet you would see a sharp increase in rollovers if tractors suddenly started having that feature.
/ Do any 3 pt hitches provide downforce? #20
My Danuser PHD has that kit, but I致e never used it, or needed to. Biggest problem here are the bowling ball size rocks you may find. Hit or miss.
Now I can稚 remember or figure out why 2nd hose had to go to fill port and not other SCV port? I understand 2nd hose is the return line from a relief valve on kit (i.e. cylinder is single action), but why couldn稚 2nd hose still be connected to SCV?
The return needs to go to a direct return to tank port. Yes it can have a coupler on it, but it needs to return with no real restriction.
The rod needs to retract as the 3pt hitch is raised. How would this even be possible if you were simply using the SCV? You need the fluid to flow in one direction to extend the rod and add down pressure. Then the fluid needs to flow in the opposite direction to allow the fluid to leave the cylinder which allows the 3pt to be raised. The fluid needs to be flowing out of the cylinder at the same exact time that the 3pt hitch is being raised. The 3pt hitch and a rear remote will not operate at the same time. So basically impossible to raise the 3pt and open an SCV to allow for the fluid to escape the cylinder.
All I can say about the down pressure option is that it took me from literally taking days to dig a hole (needing to allow water to soak in the hole at times well over a weekend) to being able to drill any hole (6"-24"dia, 4' deep) any accessible place at anytime on our 120 acres in less than 3 minutes at an idle.
All of my PHD items are the best PTO driven parts that Land Pride has. So no low buck excuses. When you have ground (decomposed granite) so hard that you can get a digging bar to spark,:shocked: you have some hard ground. :eek:
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
FORD F-250 (INOPERABLE) (A60736)
FORD F-250...
