Do any 3 pt hitches provide downforce?
   / Do any 3 pt hitches provide downforce? #1
SmallChange
Platinum Member
New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
I just got to wondering -- are there any three point hitches that can be driven downward, as opposed to just allowed to fall? Using my ripper and my auger, I often wish I could force them down. In the case of the auger I'll hang weight on the boom sometimes. Positive downward force would be a nice feature. Not that I'm going to buy another tractor to get it right now. I was just curious.
   / Do any 3 pt hitches provide downforce? #3
When you use your auger, if you have a friend with a FEL, have him put MINOR down pressure with his bucket on the top of your auger. Not too much, cause you'll break a sheer pin by forcing the auger to do more than it's capable.
   / Do any 3 pt hitches provide downforce? #4
The bit that came with my County Line auger has a screw on the end that pulls it right into the ground. The screw part was available at Tractor Supply last time I looked. I once had an auger attachment that went on a chainsaw. It didn't have a screw, the literature said it was supposed to shave the ground or something similar. What it did was sat on top of the ground and spun. I got rid of it and bought a clamshell hand digger that worked better.
   / Do any 3 pt hitches provide downforce? #5
Very few tractor models -- usually specialized Ag setups -- can provide downforce on the 3-pt hitch. I believe you can still get that option on some larger Deere models. But it's not typical for compact tractors aside from some older oddball models.
   / Do any 3 pt hitches provide downforce? #6
The newer JD 4000R series tractors have 3pt down pressure as an option. As far as your auger, just get a hydraulic down pressure kit for it and you should never want for down pressure again. ;)
Mine's a County Line also, and it has the screw too. My soil's just difficult. River bank gravel cemented together with clay. Clamshell hand diggers do nothing, and even a railroad pick or a digging bar has difficulty. I've used large masonry bits to start my holes....
   / Do any 3 pt hitches provide downforce? #8
Some post augers offer down force as an option. Problem with down force on a ripper is if down force could be applied traction to pull ripper would be significantly lowered as DF was applied
   / Do any 3 pt hitches provide downforce? #9
Boy oh boy! You've really got it rough. I hope you find something that works.
In another thread a few folks around here put me onto some special augers including smaller and stronger ones. I'm sitting tight until the need reaches the $$$ threshold. Which might not be all that long....
Rooster Artwork (A55758)
Rooster Artwork...
2021 Kubota SVL75-2 Track Loader (A55315)
2021 Kubota...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2013 Nissan Rogue SUV (A56859)
2013 Nissan Rogue...
