2021 Kubota SVL75-2 Track Loader (A55315)
Item Details
Auction ID
55315
Make
Kubota
Type
Miscellaneous
Year
2021
Auction House
Fastline Auction, LLC
Model
SVL75-2
North Carolina
Description: Engine gross horsepower (SAE J 1995): 74.3 HP (55.4 kW) Rated operating capacity (35% of tipping load) : 2300 lbs (1043 kg) Bucket breakout force : 6204 lbs (2814 kg) Operating weight (Including operator weight 165 lbs) : 9039 lbs (4100 kg); Kubotas unique vertical lift is designed to deliver an exceptionally long reach of 41.7 inches (SVL75-2) and 40.7 inches (SVL95-2s). In addition, the tip of the arm is optimally shaped for a tall hinge pin height of 119.1 inches (SVL75-2) / 128.5 inches (SVL95-2s) for easy dumping into trucks. Standard Two-speed Travel Shift from low gear at 4.7 mph (SVL75-2) / 5.0 mph (SVL95-2s) to high gear at 7.1 mph (SVL75-2) / 7.3 mph ( SVL95-2s) to get the job done faster. Pilot Valve with Shuttle Piston This ensures consistent oil flow which improves stability when going straight. Higher Ground Clearance A high ground clearance of 11.7 inches (SVL75-2) / 11.5 inches (SVL95-2s) lets you travel over large obstacles with ease. Strong Traction Force Kubotas original track lug design gives you more grip and a stronger traction force of 9678 lbs (SVL75-2) / 12178 lbs (SVL95-2s). Year: 2021 Make: Kubota Model: SVL75-2 Serial #: KBCZ052CJM1L63534 Hours: 646 Stock #: E79463 Enclosed Cab: No Lift Capacity: 2300 FASTLINE SALES REPRESENTATIVE(s) Nick Herring nick.herring@fastline.com 919-922-2854 Item Location - Address: Provided by Seller Item Location - City: Fayetteville Item Location - State/Province: North Carolina Item Location - Postal/Zip Code: 28306 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
see lot description, multiple locations, KY 40010
Starting Bid: 15000.00 USD
Auction Finishes: November 18, 2025 at 06:26 PM
Click Here To Bid Now!
Happy Bidding!
UNUSED SET OF FUTURE 25', 4 GARAGE JUMPER CABLES (A57192)
UNUSED SET OF...
JOHN DEERE (2) ROW PLANTER (A57192)
JOHN DEERE (2) ROW...
2025 Ligchine Spiderscreed Concrete Screed (A55851)
2025 Ligchine...
HOOD FOR KUBOTA L3302 (A57192)
HOOD FOR KUBOTA...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A57024)
Midwestern...
2019 Caterpillar CB24B (A53317)
2019 Caterpillar...
