Ditch Witch!
/ Ditch Witch! #1
fatjay
Elite Member
Eastern PA
Not enough
In preperation for my new garage build, I bought a ditch witch J20. Starts, runs, digs, needs a bit of work. Needs choke cable, spark plug cable, air filter, and possibly key switch. When you turn the key off, the machine doesn't shut off. It's a bit hard to start on ether. The spark plug wire is broken inside the wire, I push the wire the second cylinder it fires up. Otherwise it doesnt leak, doesn't smoke, power steering, angle, etc all work. I think $1,125 was a good price.
Anyone know a good place to get parts or a manual for this?
/ Ditch Witch! #2
Your local DW dealer should be able to supply what you need...may find a less costly manual on e-bay etc...
They are usually very good at helping with parts...they aren't exactly cheap though....great machines !
/ Ditch Witch!
Nearest dealer is 75 miles away. Went to their website, and full manual and parts catalog. Most of my machines I don't have luck with that. Will pull it into the garage tomorrow and take it apart to see how things work.
/ Ditch Witch! #4
My son has a DW. Great machine when you need it. Sounds like you got a good deal.
/ Ditch Witch!
Garage I'm building needs power/water and it's quite a distance from the house. I have to do the power before the building inspector and the water after the building inspector. I also want to run power to my shed, it'd be nice to have a light and outlet for a battery tender in there, and it's way at the back of the property line. The people that installed the power to my pool pump buried the lines 6" deep, so I also want to re-run those.
/ Ditch Witch! #6
I can only speak for DW of GA but I usually have parts within 2 days often in one day...they are very good for fast shipping and they are also very helpful on the phone...they actually let you talk to their mechanics etc...
I have a 3610 w/ back hoe...
/ Ditch Witch! #7
thats a good deal...finish up your work than resell it for what you paid... if not more. Ive seen those go for ridiculous prices at auctions this year.
/ Ditch Witch!
In the garage ready for tear down.
/ Ditch Witch! #9
Is that a Wisconsin engine on that one? I remember coming across one like that a couple years ago an electrical outfit owned it. Sure don't seem them on utility jobs as much as I did growing up directional drills sure seem to have taken everything over these days.
/ Ditch Witch!
Yes it's a wisconsin twin. I'm told it's very similiar to the wisconsin vh4d V-4 engine in my bobcat. Or at least similar era.
The distributor cap and plug wires are one piece, not good since one of them has a break inside the wire. I yanked the bad one out, drilled exposing the aluminum, then used a tiny bit so I could feed a new spark plug wire in and solder it. Went to the auto store to pick up a $16 universal spark plug wire only to find out that they're not made of metal anymore. Apparently it's some carbon fiber thing in the middle of modern wires, which confuses me greatly since carbon is among the least conductive substances. So I drove all the way to tractor supply and picked up a set for a ford 8n, confirmed they were copper core, and got it together.
Next issue was the ignition. It would start, run, but when you turned the key off, it would keep running so I had to put my hand over the intake on the carb to turn it off. Someone did a hack job on the wiring and wired it all up wrong. So I cut it all out and started fresh, this time with one of my favorite modifications, remote start. A key fob controls 3 relays, one toggle for ignition, one momentary for starter, and one toggle for lights. I have it on my kubota and had a spare kit so I'm replacing the key switch with a red indicator light telling me the ignition is on.
Tomorrow I'm looking to tackle the air cleaner and see if the alternator works. Then change the oil, check all the fluids, belts, grease points, and pull the front tire which has a wobble and see if it's a bent shaft or bent wheel.
/ Ditch Witch! #11
Using ether to start an engine can be catastrophic. If you absolutely have to spray it into the intake to get it to fire, it's best to have the engine turning over before you start the spray. At least then it sucks the explosive juice in to all cylinders. You get it loaded in one cyl. and you may be finding pistons that come apart (quicker).
/ Ditch Witch! #12
Carbon is actually a great conductor in most forms. Brushes for brushed motors are made out of it.
/ Ditch Witch! #13
Want to cause someone some problems...take a lead (graphite/carbon) pencil and make a bunch of marks on the porcelain part of a spark plug...hehehe...!
/ Ditch Witch! #14
Or draw a line to all the posts on the old style distributor cover
/ Ditch Witch! #15
That DW is awesome! When you get done with your garage trenching you should be able to make a good sale on it. :thumbsup:
/ Ditch Witch! #16
It looks like you got a very good deal in spite of some of the jury rigged attempted fixes you found. I'm glad you found suitable spark plug wires, automotive type are all carbon to prevent interference with radio frequencies and computer components. I understand how it put you in an uncomfortable position with the wires being one with the cap, probably costly to replace.
That having been said, they serve the purpose well, I put an automotive set on my TO 35 five or six years ago and they work fine.
I will be following your project, I should do something similar, I get tired of stringing multiple extension cords to the sheds to keep the batteries in shape.
/ Ditch Witch!
Minor repairs and this thing rocks. Moved at a good speed too.
2CEE24C8-1B39-4D4C-991A-360FBE86A42C.jpeg7DE0CF24-60C7-4277-8000-B3DFB4451BAD.jpeg6944AE7C-6F56-4030-8805-85876E46E68E.jpeg
2014 Takeuchi TB260 Midi Excavator (A61572)
2014 Takeuchi...
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
2024 14ft Pairboat Flat Bottom Mud Boat w/ Mudd Buddy HDR 5000EFI 40HP Mud Motor (A61574)
2024 14ft Pairboat...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
