flash back arrestor valves
/ flash back arrestor valves #22
What was the old show where to fend off attackers the group had an angled cradle they would put oxygen bottles in and knock the valve off with a sledge for an instant missile? Was it the A-Team?
/ flash back arrestor valves #23
This thread has prompted me finally to order arrestors and check valves for my oxy-acetylene set after 35 years! :thumbsup:
Now I'm wondering if an arrestor is also recommended for a propane "weed" torch used with a standard 20 lb tank? :confused: I recently bought this, but haven't hooked it up yet. Propane Torch with Push Button Igniter
the regulator valves i purchased on Amazon claims can be used w/propane.
/ flash back arrestor valves #25
those aren't needed for propane, it don't explode when compressed, like Acetylene does.
/ flash back arrestor valves #26
NO because there is no opposing pressure (force) to force flame back from "torch handle" back to regulator, besides most weed burners do not use regulators and gas escapes orifice in burner at tank pressures (at about 70ー f its atout 125 PSI)....
Dale
/ flash back arrestor valves #27
Acetylene Arrestors work for propane as well.
/ flash back arrestor valves #29
After reading this Thread I am looking into new replacement Arrestors, and thinking both ends of the hose isn't a bad thing even my Torches have them built in.
Thanks for all of the info posted, good advice !
/ flash back arrestor valves #30
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
FRONT MOUNT BLADE W/ MOUNTS (A63291)
FRONT MOUNT BLADE...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
