   / Your last generator Maintenance Run #3,401
I have customers in the Cocane Business for the Pharma Industry. Man tells me that nothing gets done in China without greasing palms.
Saw a shipping Documentary on the Suez Canal. Without a prescribed number of cartons of cigarettes, you can wait forever for your ship to get clearance to go through.
   / Your last generator Maintenance Run #3,402
After recovering from thanksgiving I felt ready to finally give my MEP-952b APU a good run while measuring fuel consumption and power output as accurately as possible.
Below is a photo of my Excel spread sheet.
The entire house was supported in addition to a 1500 watt heater for added load.
My hot air wood furnace was cycling on & off during the test.
I used 105 amps for my calculations which was lowest reading.
Surges up to 160 amps occurred as appliances cycled on & off.
I believe the data is accurate.
If you see errors please bring them to my attention.
90cummins
90cummins
Real data :thumbsup:.
At a glance, solid math...... looks like about 30L (8 gal.) for a 24hour day.
Great planning exercise..... you also added some headroom with that 1500w heater, and won't necessarily run continuous.
IIRC, you have a sizeable cache of fuel on hand, so I'm sure it's comforting to know exactly what your minimum run-hours will be with no refill.
You've checked off most of the "boxes" on your system....... one thing of interest would be an extended run in the dead of Summer..... I suspect your cooling fans have plenty of capacity, but that delta T would be interesting.....
:thumbsup:
Rgds, D.
   / Your last generator Maintenance Run #3,404
This is a photo of my systems SCP showing actual DC input and AC output.
Average conversion efficiency is 84%.
90cummins
90cummins
One thing I liked on the lesser Xantrex inverters (1 to 2kw range, not as smart as yours) is that the idle current is also very low.... it all helps during extended outages....
Rgds, D.
   / Your last generator Maintenance Run #3,407
I thought the efficiency was rather high then I realized the calculations were the DC values so I added data showing actual AC power produced at 84% efficiency and the cost.
90cummins
Not sure on your cost units..... is that kw/hr ?
Rgds, D.
   / Your last generator Maintenance Run #3,409
Rgds, D.
The upper right watt values (2940.00) and (2469.60) are watts/hour.
The lower right values are Kw’s/gal generated and the cost per 100Kw’s.
90cummins
   / Your last generator Maintenance Run #3,410
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
Chop Saw and Max 43 Plasma Cutter (A54865)
Chop Saw and Max...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A55853)
2005 Northwood...
