Cut the Cord and switched to an Antenna for TV
/ Cut the Cord and switched to an Antenna for TV #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I've been wanting to do this for awhile, but struggled making the decision on what to buy. Too many options and opinions that overwhelmed me. Then last week our Dish stopped working. They had to have somebody here for them to fix it, which I understand, but with our schedules, that meant waiting a week until that happened. My wife wasn't happy, so I went to Home Depot, Lowes and Best Buy to see what they had. Just based on the boxes on the shelf, I went with the Clearstream 4Max HDTV Antenna with mount from Lowes for $149.
I also bought 50 feet of new cable.
I ran the new cable from the back of my TV out through my garage and connected the antenna temporarily outside on my truck to see if it worked. I didn't have it facing South like I wanted it to, but thought this would be OK to see if it worked. According to Antennas Direct | TV Transmitter Locator and Mapping Tool I have 13 channels out there. After connecting everything, I ran a search through my TV to find them, and it worked great. We got all 13 channels, and the picture was amazing!!!
First problem that we discovered is that my surround sound doesn't work. I'm still trying to figure that out. The sound from the TV is OK, so it's not a big deal, it's just something that I'll have to figure out eventually. ROKU and the DVD player are now plugged into the back of the TV instead of my receiver.
Big surprise is that we now only use the remote for the TV to do everything while watching TV. When using the ROKU, we use that remote for everything except volume. We still have to use two remotes when watching something on the ROKU.
There are 4 towers in my area, one for each network. Each network has other stations that it broadcasts from. For example, NBC is 56.1 then there are three other channels that are 56.2 and 56.3 and 56.4 It's real easy to figure out.
So then I decided to mount the antenna permanently to the bracket that my Dish satellite was using. It was a simple swap from one to the other. This put it at the top of my second story. No trees in the way and a clear view facing South. I could only get 2 channels from that location. Depending on what direction I pointed it, and I tried 8 different angles, it was always a different combination of two channels. I have no idea why this happened. It makes no sense to me, but it is what it is, so I took it down and mounted it above my garage door. This has it facing kind of SSW, which is one of my attempts from the other location. Due to the wall of the house being where it is, I have to angle the antenna down slightly and it's cock eyed instead of level like it was on the second story. And it works perfectly in that spot.
If I had not accidentally tested it in a location that I didn't think was ideal, I might never have gotten all 13 channels right off the top like I did, and I probably would have returned the antenna because in my opinion, it didn't work.
While running the cable through my trusses over my garage, I attempted to connect the new cable to the old cable from the Dish that went through the wall and outside to where it comes back into the house behind the TV. I figured it would be the easy way to do it, but I lost the quality of my picture from that short length of old cable. That might have been my problem with the Dish? I drilled a new hole through the wall and ran the cable all the way to my TV, which gave me a clear picture.
It's been 5 days now since I started all this and today I just finished it up by hiding the cable up in the trusses. We are very pleased with the result and looking forward to saving $120 a month for Dish.
/ Cut the Cord and switched to an Antenna for TV #2
all you can get is 13 commercial laden channels though!. and the hours that something worthwhile is on is very limited, and filled with commercials!. no guide or DVR either.. you have to watch what's on when it's on, no recording!..
There is a guide, but it only show's what is on each station at that time. Not sure if there is a way for it to show what's on next. One of them is in Spanish, so I really only have 12 watchable channels. All we wanted was the 4 main networks, the rest are a bonus.
/ Cut the Cord and switched to an Antenna for TV #4
You can always make a TVGuide account for your local area with favorite channels and bookmark it. That's what I did when I ditched the cable ages ago.
/ Cut the Cord and switched to an Antenna for TV #5
ABC, NBC, CBS, CNN ?
I would not watch TV at all if those were my only choices.
/ Cut the Cord and switched to an Antenna for TV #6
And there are DVR's you can connect to over the air antennae. That would be a must for us, because we never watch anything live so the commercials can be fast forwarded thru.
No DVR, and don't have a reason for it. We've found that if we miss something, we can almost always find it on YouTube.
/ Cut the Cord and switched to an Antenna for TV #8
Which is still 13 more than some of us can get. Watching what's on when it's on is not a big deal to me, if I miss something, oh well.
/ Cut the Cord and switched to an Antenna for TV #9
I am hooked on free OATV, love it. I get about 60 stations, including substations and it is about all I watch.
We also have YoutubeTV, Philo and Netflix and I wish I could wean my TV Adict wife off of at least 2 of those.
/ Cut the Cord and switched to an Antenna for TV #10
Good for you! :thumbsup: We had DirecTV for about 17 years and it kept going up, and we really only watched about half a dozen channels. So, we bought an antenna, removed the satellite dish, and, like you, mounted the antenna on the old dish mast out on the garage. I originally had wired the satellite to a head-end, then distributed it back throughout the house so that any TV in the house could watch whatever was on the dish, so I just popped the antenna onto the same coax that I used for the dish. I added an amp at the antenna, and we now feed living room, bedroom, basement laundry room, etc... all from the same antenna. When we did that about 4 years ago, the local stations had about 2 channel each, so about 11 channels. Today, we have 32 channels! Only 1 is spanish and 2 are religious. NBC, CBS, ABC, PBS, FOX, Start, This, H&I, Justice, Escape, CourtTV, Quest, Bounce, DABL, Ion, GRIT, LAFF, LIGHT, HSN, MeTV, Movies!, Telmndo, Decades and some locals. Very nice! :thumbsup:
Coupled with the ROKU box and our paid Netflix and we have more than enough to watch.
/ Cut the Cord and switched to an Antenna for TV #11
That's about the same list that I get. I enjoy a lot of the old movies on the Movies! channel. The biggest issue for OTA TV that I see is for sports enthusiasts, which I'm not.
/ Cut the Cord and switched to an Antenna for TV #12
Eddie, depending on your Roku model, you might have volume control on it. Check the right side of the remote for volume buttons. You can also use a roku app on your phone instead of the remote. That works well too.
/ Cut the Cord and switched to an Antenna for TV #13
Been doing this since 2013 and it works well and keeps me happy. We also do Netflix and AppleTV. Don't miss cable/sat at all and it saves a lot of $$.
/ Cut the Cord and switched to an Antenna for TV #14
Speaking of ROKU, some of my savings gained from the antenna goes towards buying batteries for the ROKU remotes, particularly the ones paired to the sticks. I have never seen remotes gobble batteries so much. AAA batteries. We set them on solid surfaces because I read they were motion activated, but I do not know that for sure.
/ Cut the Cord and switched to an Antenna for TV #15
Good going Eddie... it is not like you can't go back if you want.
Never left antenna... just added a digital converter with rebate to the old Zenith Color Console...
60 channels and always something on...
I looked around for the old freebee antenna that came with TV's back in the day... I thought I had one in the closet along with the round UHF one.
The only tricky part is the antenna has to be just right on top of the TV... I mean just right... works fine until someone dusts or moves it... I have witness marks now so no big deal.
If I think back to how much 50 years of cable would have cost it would be staggering.
Managing rental property many of which are low income it always amazed back in the day that it was essential each room have phone and cable jacks. I never have had a Section 8 family without cable and a nice TV for the time... projection, flat and even curved...
To this day some think I am pulling their leg when I say I have never lived in a home with cable... and still have a working rotary landline...
The point is I hate recurring charges... it is like a treadmill you never get off.
Since I put in solar about a year ago I have not paid for a single kW through net metering... there is still the monthly service charge but the $100 utility credit for the power outage covered most of my first year...
Now if I could just get rid of the exorbitant Water/Sewer bill!
/ Cut the Cord and switched to an Antenna for TV #16
I may have a future remote problem as the Zenith Space Command takes a battery that is no longer on store shelves... good thing is the battery tends to last for several years...
If the day comes I will just have to get up and to make changes.
The original Zenith Space Command doesn't even use batteries... have a portable set in the garage... no batteries required... it works by sound.
/ Cut the Cord and switched to an Antenna for TV #17
I have never had a Water/Sewer bill!!! I also only have OTA with Netflix. I have never had cable. There is no cable here. I can't handle the infomercials during TV shows, so I got a TIVO with lifetime service.
/ Cut the Cord and switched to an Antenna for TV #18
We recently got high speed internet connection;dropped Direct TV($182/month;and Verizon telephone at $82.00,slow internet at $50.00)
High speed cost $50/month+$40.00 for unlimited phone and Sling for $54.00.Big savings and lots of T.V. to watch.Still have an antenna for the local stations.
/ Cut the Cord and switched to an Antenna for TV #19
City limits and water/sewer bill not optional...
Monthly charge BEFORE a drop of water is used is $150... so $1800 annually.
Summer water can add as much as $300 month.
It is just not here but other places like South Lake Tahoe... 2000 gallons a year... yes 2000 gallons annual use last year and still $1300... having the service turned off means water company pulls meter... to reset meter costs thousands of dollars...
This is how the district keeps year round revenues when use is primarily Summer months.
/ Cut the Cord and switched to an Antenna for TV #20
I grew up with OTA as the only option. As a kid I was the remote control and got yelled at when I rotated the channel dial too fast - click click click click click - YOU ARE GOING TO FAST YOU WILL BREAK THE TV! I also got to adjust the antenna rotor.
When we had a house in town we had cable. 500 channels of the simpsons playing at 1 hour offsets, and only 8 hours of programming broadcast 3 times a day and for each time zone! Only $100 a month! No thanks.
Moved back to the country and went back to OTA. Get 39 channels, all network channels and most of them are broadcast at higher definition than what you get on cable/sat. Windows Media Center used to be the goto PVR until micro$oft discontinued it. My big splurge was getting a TiVo OTA for $70/year for the guide and silent PVR. I hardly ever watch live TV anymore and with commercial skip never watch any commercials. No specially channels but thats what YouTube is replacing.
The negative to living in the country is that streaming is near impossible and internet service is worse than what you get in 3rd world countries at 1000x the cost.
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2016 Ford F-550 4x4 IMT 3203i 2 Ton Crane Mechanics Truck (A61568)
2016 Ford F-550...
2022 Case CX220E Hydraulic Excavator (A61567)
2022 Case CX220E...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
