Carpentry Of Homes,,, Nail Diameter,, and Codes?
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #41
I use a hammer for beating things. For smaller projects I much prefer 3” screws. Try ripping a screwed board apart and repeat with nails. If I felt inclined to use nails I’ll use my framing nailer. I don’t frame houses but I’ve done my fair share of carpentry.
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #42
I would be ashamed of 4 hits.
For one, the hammer should be quality. I like vaughn 21 oz framers, then I cut down the handle by a couple of inches and sand it round. I then wrap about 20 wraps of black electrical tape about 2 inches down from the head, just to protect the wood. The wrist should never bend in the hit, the bending happens at the elbow. The swing should be through the nail, not stopping at the nail. One tap to set the nail and then two hits to drive it home.
My dad was a general contractor. When I was 14 my dad gave me a job for the summer. I shadowed an old time framer. There is not a $ amount I could value that summer with him. He only had me hand drive all summer. I could not help out until I could drive 50 nails into a rail road tie without bending one.
Practice with a box of nails, I bet by the end your doing 5 hits. After 10,000, you will have it down to two...
I anxiously await the video!!!
Well, I am SUPER impressed with the $28 METABO Palm Nailer,,,
That is the best money I have spent on a tool in a LONG time.
A video of using it would be worthless,, you got to try it to believe it,,
There is no "trigger" as such, the nailer just senses that you are putting a slight pressure on the nail, then the nailer takes off, and drives the nail in.
I was building a set of shelves, several of the nails from the framing nailer did not fully drive, the wood was too hard.
I tried hitting the nail with a hammer, the nails were TIGHT,,
I picked up the palm nailer, the nailer effortlessly drove in those nails.. If I had used a hammer, I would have bent a couple of those nails.
I do not think the palm nailer could bend a nail,, at least in my use, no nail even attempted to bend.
The nails that were driven with the palm nailer acted like the nails were going into pre-drilled holes.
AND, the palm nailer is TINY,, it is half the size of what I was expecting,,,
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #44
We use them for between joists and in tight spots. They will bend a nail if it hits a knot or something that stops its progress.
They are great tools though.
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #45
That they are! I was always skeptical and never had/owned one when I was a framing contractor. Years later, I was getting a new framing gun and it came with a ‘free palm nailer’..... I was amazed at how easy it works, especially in the tight spaces. If this one ever stops working, I’ll buy another!
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #46
The ultimate usage for the palm nailer (INMHO) is to fasten joist hangers, there it outshines anything else.
Screws, well I'm slowly getting converted but for speed I still like a good nail gun.
OK, on a deck screws won't protrude after a while while nails (perhaps 5/6 yrs later) want to have a % driven back flush.
A lot will depend on how you quoted the job, nails will be low ball while screws a % higher.
LOL, I once did a large deck and had Stainless nails and client opted for that as well a best treated wood available.
On aside the SS nails cost me less than others as I won them on a liquidation auction. A nice Win/Win.
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #47
I have a palm nailer. Got it free from someone. Still never used it.
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #50
You are why they made nail guns...
I don't know about anyone else, but I'm still anxiously awaiting the video of 16 in two hits. :D
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #52
You're not the only one...
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #55
That guy knows...no bending of the wrist.
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #56
Looks to me like he is "releasing" the wrist...it's the way to get the most power out of a swing...ask any golfer...
As for hammers...I'll take a 'Stanley Rocket'...all the weight is in the head...!
BTW..."releasing" the wrist allows all the energy to exit the arm/hand...rather than absorbing part of the energy as with a locked wrist...
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #57
I would rather have my entire arm as a fulcrum than any fancy wrist work...
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #58
Something else that is often misunderstood is the weight of framing hammers...
A standard claw hammer usually weight 16oz....typical framing hammers usually weigh 20, 22, 28 ounces...
An experienced carpenter can sink the same nails with the same amount of blows whether it's a 16oz. or a 28oz hammer...the reason framing hammers come in heavier weights is for moving "things"...it's much easier to move sill plates, heavy framing member, trusses, timber etc. with a heavier hammer...
original "framing" hammers often came with extended handles and hatchet blades rather than a claw...
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #59
It's really more about letting the tool do most of the work...and getting all the energy generated from that fulcrum and applying it to the head of the nail...there is no shock to the hand or arm like there is with a stiff grip at impact...
on a side note:
Nail guns have done to the skill of driving nails what calculators have done to the ability to do simple math in the head...
/ Carpentry Of Homes,,, Nail Diameter,, and Codes? #60
Why yes, stelito framing hammers are titanium and only weight like 9oz. The speed of the hit has always been of a bigger factor than weight.
However, the most important part of driving a nail...hitting the **** thing square. Professionals never bend nails, armatures bend nails.
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A62129)
2019 CATERPILLAR...
LandHonor LHR-UBF12 12in Utility Blower Fan (A60352)
LandHonor...
2006 ISUZU NPR 4X2 BOX TRUCK (A59908)
2006 ISUZU NPR 4X2...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
2016 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Truck (A61568)
2016 Globe Trailer...
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
