Snow Equipment Owning/Operating Trygg chains installation
/ Trygg chains installation #41
I found that without using the special TRYGG jack, the chains are never as tight on the tire as they are intended to be.
I tried other tools but once I bought the special tool (expensive $280 in Canada) it was like having a gorilla helping me.
There are other cheaper styles available and skilled owners could make one up.
Dave M7040
/ Trygg chains installation #42
The attachments show up fine now and nice job on the fix.:thumbsup: Glad to hear it is more of a wobble than a rough ride. I'm really expecting these chains to ride quite smoothly, especially compared to the ladder chains I had on the front tires last year. Man those things rode rough on ice.
Dave, thanks for the pics of the chain jacks. The screw type look like they should be fairly easy to make. I see a little project in my future.:)
/ Trygg chains installation #43
Dave M7040
Interesting. It looks as though Trygg wants their chains mounted tightly. The OFA EKO chains specify that they want them mounted loose: you are supposed to be able to fit a fist in under the chain (and in fact they will not do warranty coverage for chains showing premature wear caused by over-tightening). So I've never attempted to use a jack or any sort of tensioning device. I just lay them on the ground behind the tractor, studded side facing up, tie a loop of string near the center of the end cross chain pass through a hole in the rim and back on to the center of that cross chain. (The directions say to just hook the loop over the tread, rather than passing through a hole on the rim, but that tends to come off of my older tires.) Then I just drive the chains on to my tire, stopping to spread and center the chains a couple times on their way around. I stop when the starting end connectors get about half way up the back of the tire, make the connection and I'm done. No significant wrestling with the end to get it tight, no re-tensioning after driving it a bit. It's simple and quick.
/ Trygg chains installation #44
I also find it interesting Trygg wants the chains so tight. If you have a very tight circumference chain bridging the deep gap between two lugs on an R1 tire and then run over something like a root or rock so that significant weight is supported by the chain over the gap it will cause tremendous tensile forces to be developed in the chain so that when it flexes, which it must, it is with a grinding action between the links. Like the effect you get stringing a tight clothes line and hanging a small weight on it can produce tension in the rope 100 times greater than the weight. If the chains are loose they can flex and bottom out and there is no tension or grinding action between links as they flex. Two totally different approaches for similarly designed chains..............??????????
EDIT: Even w/o the root or rock any flexing will be abrasive just from the installation tension.
gg
/ Trygg chains installation #45
I have provided some info regarding TRYGG chains and a tight installation.
TRYGG maintains a loose chain will have much greater wear and damage from pavement impact.
The diamond pattern of studded chain wrapped around the tire circumference is only completed by joining two diamonds using open hooks.
If the chains are not tight the diamonds will come apart.
When my too long chains came apart, the open hooks grabbed unto my tractor's step and locked one back wheel which was scary.
Dave M7040
/ Trygg chains installation #46
interesting, none of mine have an open hook they use clevises or the open link that has to be twisted and turned just right to be hooked or unhooked.
/ Trygg chains installation #47
Yeah, them open hooks are a accident waiting to happen. I always thought chains should be loose enough to walk around the tire a bit while in use.
We received a little 8 inches of snow yesterday so I did my first snow run with the chains on At first didnt like them at all, sometimes shaky sometimes bouncy. But after couple of driveways it seems like they settle un better and no more weird feeling of bounces and shakes. Except for short random moments.
After my run (7 driveways and 8 km of roading) they hold
good but got loose a bit, so I'm gonna retighten them to see what happen.
Looked at your pics of the chains hooking your tractor's step. That must have been a scary moment, don't want that to happen at road travel speed.
/ Trygg chains installation #49
I can see how open hooks or S hooks could cause a problem if the chains were loose. OFA EKO chains have a different method for joining the two diamonds when installing the chain. They have a special chain link with a diagonal cut in the side:
Two of these are attached in two places to the trailing edge of the last diamond pattern on one end of the chain, and two more are attached to the leading edge of the diamond on the other end of the chain. Once the chain is wrapped around the tire, the links can be connected together, but only if they are in a specific orientation. Once connected, they act like regular chain links and will not come undone unless they are moved to that same orientation and pulled apart. The overall circumference of the diamond section is adjusted to fit slightly larger or smaller tires by adding or removing extra links (which is why I happen to have spares).
I have never had these come apart in use. In fact it takes a bit of fiddling to get things just right when I do want to take them apart.
/ Trygg chains installation #50
I just put mine on one tractor today and they are not tight, I use clevises for most of my fastening.
Also put the chained up tires on the sander truck in preparation for tomorrow and Monday.
/ Trygg chains installation #51
I finally got around to making one of those chain tighteners. I had all the materials laying around, so the cost was basically nothing other than my time. I suspect I will appreciate it when I need to install the new Trygg chains.
/ Trygg chains installation #53
Nice work..... even painted Kubota orange!!
The tool will be a big help
Dave M7040
It was the pics you posted that gave me the inspiration to make one and the bright orange color will make it easier to find in my messy shop.:laughing:
Thanks for posting those pics.
John
Nice work really neat ! What size of threaded rod are you using ? I might want to build one myself someday. Probably painted red :laughing:
/ Trygg chains installation #55
Hahah overinflating the tires is not a bad idea :laughing: but it might be my last post here before I hit 120 psi :confused2:
I will try to adjust them the best I can. I just found it weird that they are almost a foot longer of what they are supposed to.
LOL, one size fits all!
/ Trygg chains installation #56
I just winged it and used 1/2" rod.
I'm pretty sure the chains don't care what color you paint the tightener,lol.
Ok nice. That tool is going make install easier for sure, wish I had something like this when I installed my chains.
I agree... chains don't care about the color since they didnt care about my raging red frosted face installing them at -15°C lol :laughing::laughing:
Give us some update of how your tool help after your chains are installed.
/ Trygg chains installation #58
Seems like you could use a high lift jack to tighten chains pretty easily.
/ Trygg chains installation #59
Before investing in the TRYGG tool I tried all sorts of other stuff. Pipe clamps, bar clamps, ratchet straps........
You need a tool which you can swing out of your way while still maintaining the tension.
Wrestling with a heavy jack might be fine for someone young but.........
Dave M7040
After 2 days of mild temperature (7-8°C) and some rain, today temp dropped to -20°C covering the entire driveways with a nice hard smooth layer of ice so I had the "chance" to really test the chains when hauling firewood in loader bucket for the house. I got to say that these chains are amazing gripping through ice making the tractor safe to operate when close to buildings and on steep areas.
Steering was non-existent on that rink quality ice... steering brakes took care of that. From no cab to cab and no chains to chains I think I'm going to enjoy winter a lot more this year :licking:
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
213098 (A64276)
213098 (A64276)
John Deere BW17029 Tractor Bucket (A65640)
John Deere BW17029...
Case HI Combine w/ 2010 Headflex (A62613)
Case HI Combine w/...
