Broke Down and Got One of those Fake Drawbars :-(
   / Broke Down and Got One of those Fake Drawbars :-( #12
How are those locks at the lift arms?
Are they strong enough to prevent twisting if you're using a ball hitch and a heavy trailer?
I've added the brackets that prevent rotation by connection to top link as it seems more 'solid', but it does limit how tight you can turn with some trailers, especially a camper we had that had a "triangle" instead of a "tongue". They also have one with a receiver that moves the ball back further.
View attachment 629733 View attachment 629734
$55 & $75 at Funkworkz
As long as there is no slop allowing the lift arm to slide on the drawbar pin, there is no way that bar is going to rotate.
You would have to look at one from a better view to believe that they work well.
   / Broke Down and Got One of those Fake Drawbars :-( #13
When a person wraps a chain around a flat 3pt hitch drawbar and attempts to tow another tractor, the drawbar needs to have something to stabilize it so the flat side faces the ground or that person's drawbar might get bent like mine. (
   / Broke Down and Got One of those Fake Drawbars :-( #14
Use a shackle or a drawbar hook to attach the chain to the cross drawbar. No stabilizer needed.
Bruce
   / Broke Down and Got One of those Fake Drawbars :-( #15
Hmmmmm,, My 10,000 pound tractor was not able to bend my bar,, pulling a rock that was all the tractor would pull,,
I pulled that rock out of a hole, sliding up the steel square tubes,,,
Maybe my CAT II bar is thicker??
This is a BIG rock!!
   / Broke Down and Got One of those Fake Drawbars :-( #16
^ The flat side appears to be facing the ground so you’re using the thick side of the bar instead of the thin like Stuckmotor suggests.
In the picture taken from the tractor seat, the chain does appear to be wrapped around the bar?
Edit: It DOESN’T appear to be wrapped around bar
   / Broke Down and Got One of those Fake Drawbars :-( #17
That's what I thought would happen when I tried it. The bar turned sideways and soon it was smiling. ( I suspect your Cat 2 bar is thicker and maybe harder steel. I didn't intend to use mine much and bought the economy model.
   / Broke Down and Got One of those Fake Drawbars :-( #19
I wonder if wrapping kept the bar from turning???
   / Broke Down and Got One of those Fake Drawbars :-( #20
I use a drawbar between the lower arms, and am also aware of the potential issues. I think most threads revolve around the 3 point raising, and actual terminology of what the thing is named!
Anyway, not necessary in the op's use, but I use a lock on the bar when using it to tow my landscape trailer. I prefer the no-tools type that is much harder to find. The only picture I could find of the type was actually made by "Zmansmac" (TBN poster)
These drawbar locks are a must. I've used this type of drawbar over they years and these little clamps solve lots of unsolvable problems before they occur, especially if working in the woods. Plus, there's a little fab time in making one. There's a store-bought one out there for maybe $20 but it doesn't work correctly and doesn't last very long. Make the one in the picture.
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
Zero Turn Mower (A55853)
Zero Turn Mower...
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
BOMAG SMOOTH DRUM ROLLER (A58214)
BOMAG SMOOTH DRUM...
