Time for a new HVAC 5 ton - Help!
/ Time for a new HVAC 5 ton - Help! #61
The owner stopped by and specified Tempstar... we bought several which I had the pleasure of installing... ducts, refrigerant, concrete pad, attic pans, electrical etc...
The irony is they don't tell you that Tempstar is Carrier, added they have cheaper lines available than what is listed here...
I can assure you, the name does not make the quality on how long the equipment will last.
BTW, the sound of forced air being anoying is either a question of equipment or duct size not being correctly sized.
/ Time for a new HVAC 5 ton - Help! #62
I have been installing Goodman units since 1987. Mostly heat pumps. Of all of the units I have done (I am still in contact with most customers) I have only had 2 repairs. One was a warranty for a cracked joint on a brazed joint inside the unit and the other was a leak in the outside coil caused by a steel bracket rubbing on the copper. I have never seen a compressor failure. Bear in mind that Goodman uses Copeland scroll compressors, which is a key supplier to most OEMs. Most of the other components are from large, well known suppliers. The Goodman specific parts are the sheet metal work and coils. I do know that some years ago they had issues with coils leaking when they transitioned from copper to aluminum, but that seems to be in the past these days. For nearly all brands you can put a majority of failures on the install and/or maintenance of the units, not the OEM manufacturing.
Paul
/ Time for a new HVAC 5 ton - Help! #63
Paul
Goodmans get a bad reputation because they are easy for literally anyone to buy and a lot of the units have been installed by plumbers and/or handymen without any of the right tools or knowledge to do so. As you mention, I've found them to be full of parts from all the usual suspects that you'll find in nearly any other unit. It's always all about the install.
/ Time for a new HVAC 5 ton - Help! #64
Exactly and these are professional installed HVAC systems... sounds like a tornado coming and the window coverings start moving...
Not sure what the industry position is but I found a large lazy 180 sweep on the attic air return can make for a significant noise reduction...
/ Time for a new HVAC 5 ton - Help! #65
Paul
Is copper for coils no more?
A lot of the stuff I have has copper coils with aluminum fins... and the coils have been successfully field repaired in 25 to 30 year old units.. the fins are showing their age.
Truth be told I have more issues with Johnson Controls Metasys and Pneumatic Reheat Coils...
/ Time for a new HVAC 5 ton - Help! #66
For the most part everyone is now using aluminum tubing for both indoor and outdoor coils. Most today also (say they) use microchannel coils. These are typically rectangular shaped tubes with external deflectors to increase air turbulence for better heat transfer. Aluminum can be repaired with special brazing materials, but it is not as easy as copper was.
paul
/ Time for a new HVAC 5 ton - Help! #67
Paul
Paul
Assuming (yes, understand about that word and if you can give me more info, would be appreciated) you're a "full time" one man show working from your house with a relative as a co-worker for "grunt work" to help, averaging 3 systems per month, that's at least 1,152 Goodman systems you've installed since 1987. Can you understand why I may be scratching my head if you've only had two repairs in 32 years with over 1,000 systems installed?
/ Time for a new HVAC 5 ton - Help! #68
paul
Could you please let me know what outdoor units Goodman are using aluminum for the outdoor coil other than perhaps Trane and Amercian Standard (and their sub brands?).
Also would like to know about who is using the micro channel coil other than York and Trane (their sub brands) on AC outdoor units, and Nordyne (and all their sub brands) on all indoor and outdoor systems including heat pumps. Personally, this is what I hate about Nordyne (per their micro channel system for indoor coils along with heat pumps). Most HVAC service techs would rather look at temps and pressures per their gauges over air flow, and IMO air flow becomes critical with micro channel systems, which a lot of people seem to ignore.
/ Time for a new HVAC 5 ton - Help! #69
Paul
As far as I know, all of the Goodman and most other manufacturers are using aluminum microchannel coils today.
I am licensed and do HVAC as a side "hobby". I do not advertise, but work strictly work of mouth. I do have a mechanic friend who helps out (no relatives!). Over the years I have put in about 100 Goodman systems as well as 6 geothermal units. I started when we built our house and assisted my wife's uncle who had an HVAC business and installed our systems. Then I started, with his assistance, doing trouble shooting and repair on my own (York) systems. I took a course at CC and got licensed and started helping out friends and co-workers, and then ended up doing jobs for more people. Most are replacement of existing older or deal systems. Many are change from AC to heat pumps. I generally do not do jobs that require major duct rework. being a small, part time guy I am very selective and stay away from any pain in the butt jobs. I do have a full time job as an engineering manager for a large manufacturer.
Paul
/ Time for a new HVAC 5 ton - Help! #70
Paul
You're running about a 2% failure rate, general average within most manaufacturers and not out of line. Hopefully you can understand that when you state "I have been installing Goodman units since 1987. Mostly heat pumps. Of all of the units I have done (I am still in contact with most customers) I have only had 2 repairs." that statement can be misconstrued per quality of the brand.
Given the information you've given me, I will also assume you are by far not the cheapest quote because if you're doing side work like you've described with your full time job, you don't want call backs being a pain in the butt added you mentioned no relatives which tells me you're smart LOL (in 25 years the only "relative job" I've done was my own parents home, and that was a boiler replacement, which I can live with).
If my assumptions are correct, I know more than a couple of guys like you locally in my area. Thing is, people assume since you're small, you have to be cheaper and you're not:D That said, you're not Goodman's typical customer by far.
Out of curiosity, do you push the brand or do you push the quality of your work?
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
ALLMAND MAXI-LITE II V-TWR (A60736)
ALLMAND MAXI-LITE...
2024 AGT INDUSTRIAL  H13R (A60736)
2024 AGT...
Bell 1600 Gallon Nurse Trailer (A61307)
Bell 1600 Gallon...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
CFG Inudustrial MH12RX (A60463)
CFG Inudustrial...
