CADplans
Elite Member
I had a new air handler and outdoor unit installed, basically replacing my 35 year old heat pump.
The new unit is a 2.5 ton TRANE heat pump,, the original was a 2.5 ton CARRIER.
Since the day it was installed, the air handler has been much "noisier" than the old unit.
The noise is most noticeable when the unit is in "heat" mode, as the fan speed is higher.
The unit makes way less rumbling when in "cool" mode.
The outlet of the old CARRIER air handler was 19" X 16",, so that was the size of the plenum that was built for the original install.
The new TRANE air handler has an outlet sized at 13" X 16",,, basically the plenum should be 6" narrower than the CARRIER air handler.
To simplify making the plenum, the installer built the new plenum 19" X 16",, the last 6" of the plenum simply sits on the flat top of the air handler.
The plenum was made this way to simplify connection to the existing ductwork, I would imagine. There is a 6" dead air space in the new plenum.
WAY back when,, I studied HVAC for a while,, we were taught that the plenum should be sized identical to the outlet of the air handler.
The identical sizing was to eliminate turbulent air flow, or to reduce rumbling noise as the air entered the dead space.
I have looked on line, I can not find any "rules" for plenum design,,,
My warranty period is up, I am considering remaking or modifying the plenum, to see if eliminating the dead space in the plenum will reduce the rumbling.
Am I wasting my time, or should the plenum match the air handler outlet?? Or,, are there other "rules" of plenum design??
HELP!!
Thanks,,
HELP!!
Thanks,,
